i.MX8Q Android How to enable SPDIF output
1,996 次查看
n3820fjmn2k2q
I'm using i.MX8QXP MEK CORE&BaseBoard.
As default, SPDIF output(imx-spdif) is not defined in dts file.
Can this board output SPDIF? and How to?
1,809 次查看
Hi Makoto
spdif is not supported according to Android Release Notes document included in
Android P9.0.0_1.0.0 Documentation
One can try modifications as in below dts example (check that spdif muxing options were
not affected by other modules)
linux/arch/arm64/boot/dts/freescale/fsl-imx8qxp-lpddr4-arm2-spdif.dts
fsl-imx8qxp-lpddr4-arm2-spdif.dts\freescale\dts\boot\arm64\arch - linux-imx - i.MX Linux kernel
1,810 次查看
Hi Makoto
1,809 次查看
n3820fjmn2k2q
Hi igor.
Ive refered to fsl-imx8qxp-lpddr4-arm2-spdif.dts and tried, but didnt work.
Thank you for your explanations.
1,761 次查看
relax-wu
Has your problem been solved? Can you share it?
