We are running on i.MX8Mmini-EVK using LF_v6.6.52-2.2.0_images_IMX8MMEVK.
In this environment, we are connecting the WLAN module via SDIO.
We are experiencing issues with SDIO communication failing at high and low temperature environment.
To avoid this issue, we want to change the SDIO speed from
"SDR104 mode (208 MHz) (1.8V)"
to
"DDR50 mode (50 MHz) (1.8V)" or "HS mode (25MHz) (3.3V)".
Could you please advise how to change the SDIO speed?
