i.MX8MQ – Initial code loading without USB/UUU using
2,264件の閲覧回数
ayse-yilmaz
We are developing a custom embedded system using the NXP i.MX8MQ processor. Due to strict space constraints in our hardware design, we cannot expose a USB port in the final product.
System Summary:
Processor: i.MX8MQ
RAM: 4GB DDR4
Storage: External eMMC
Intended OS: Yocto Linux running on Cortex-A53
No initial bootloader or software flashed yet (fully blank system)
Available debug interface: JTAG (SEGGER J-Link)
Our main question is:
Can we use JTAG (via J-Link) to initialize DDR and load and execute code (such as U-Boot) in RAM without using USB or the internal boot ROM boot process (i.e., bypassing UUU tool)?
Or is it mandatory to use the USB OTG + UUU serial downloader at least once to load initial code to the system before we can boot from eMMC?
Thank you very much for your help.
5 返答(返信)
2,256件の閲覧回数
Bio_TICFSL
Yes you can use jtag or you can program the eMMC or SDcard separately.
regards
2,237件の閲覧回数
ayse-yilmaz
Thank you for your support.
I found documentation related to loading firmware via JTAG on the M4 core, but I could not find similar documentation for the Cortex-A53 core.
Could you please provide or point me to any official documentation or resources about loading and running code on the Cortex-A53 core (i.MX8MQ) using JTAG (e.g., with SEGGER J-Link)?
2,188件の閲覧回数
Bio_TICFSL
one can look on
IDE - Debug, Compile and Build Tools (2)
SDK_2.3_MX8MQ_Beta_Patch(REV SDK2.3_MX8MQ_Beta)
(NXP provided IAR and Segger tool patch to support i.MX8MQuad device)
i.MX 8M Evaluation Kit|NXP
for A53 supported  Lauterbach and ARM DS-5, for OpenOCD one can look at a53 support on
Programming Guide: OpenOCD + Eclipse + Jtag debug on Uboot & Linux
2,127件の閲覧回数
ayse-yilmaz
Thank you for the references.
I have checked the SDK and toolchain patch links as well as the OpenOCD documentation you mentioned, but I could not find a clear and complete example or guide showing how to:
      * Initialize DDR from JTAG on i.MX8MQ (Cortex-A53),
      * Load and execute U-Boot or any custom binary directly into A53 RAM via JTAG (e.g., with SEGGER J-Link),
      * Do this entirely without using the internal boot ROM mechanisms (i.e., without USB/Serial Downloader Mode).
Most available documentation seems to either:
     *  Target the Cortex-M4 core,
     *  Assume a bootloader is already present, or
     *  As in the reference you provided, demonstrate debugging U-Boot and kernel via JTAG only after they have been loaded through USB and the UUU tool, rather than performing a full bring-up from a blank device.
Could you please clarify if it is officially supported to boot Cortex-A53 code via JTAG (without USB), and if so, could you provide:
      * a direct application note, app guide, or example script (J-Link, Lauterbach, DS-5, or OpenOCD)
      * or any steps regarding DDR training, code upload, and A53 startup via JTAG?
This would be very helpful for bringing up our custom hardware which currently has no pre-flashed bootloader and no USB access.
Thank you again for your support.
タグ(1)
2,111件の閲覧回数
Bio_TICFSL
For JTAG and JLink scripts supporting Cortex-A53, may be recommended to apply to segger directly:
https://forum.segger.com/index.php/Thread/4447-SOLVED-Cortex-A53-support/
NXP uses Lauterbach Trace32 as debugger tool for Cortex-A53 cores.
%3CLINGO-SUB%20id%3D%22lingo-sub-2130958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8MQ%20%E2%80%93%20USB%2FUUU%E3%82%92%E4%BD%BF%E3%82%8F%E3%81%9A%E3%81%AB%E5%88%9D%E6%9C%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2130958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3ENXP%20i.MX8MQ%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%AD%E8%A8%88%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E5%8E%B3%E3%81%97%E3%81%84%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E5%88%B6%E7%B4%84%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E6%9C%80%E7%B5%82%E8%A3%BD%E5%93%81%E3%81%AB%20USB%20%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%85%AC%E9%96%8B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E6%A6%82%E8%A6%81%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3A%20i.MX8MQ%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A%204GB%20DDR4%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%3A%20%E5%A4%96%E4%BB%98%E3%81%91eMMC%3C%2FP%3E%3CP%3E%E5%AF%BE%E8%B1%A1OS%3A%20Cortex-A53%E4%B8%8A%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8BYocto%20Linux%3C%2FP%3E%3CP%3E%E5%88%9D%E6%9C%9F%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%84%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E3%81%BE%E3%81%A0%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%EF%BC%88%E5%AE%8C%E5%85%A8%E3%81%AB%E7%A9%BA%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%EF%BC%89%3C%2FP%3E%3CP%3E%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3A%20JTAG%20(SEGGER%20J-Link)%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E4%B8%BB%E3%81%AA%E8%B3%AA%E5%95%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ECAN%20USB%20%E3%81%BE%E3%81%9F%E3%81%AF%E5%86%85%E9%83%A8%E3%83%96%E3%83%BC%E3%83%88%20ROM%20%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20(%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81UUU%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%AB%E3%80%81JTAG%20(J-Link%20%E7%B5%8C%E7%94%B1)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20DDR%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%80%81RAM%20%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%20(U-Boot%20%E3%81%AA%E3%81%A9)%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81eMMC%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81USB%20OTG%20%2B%20UUU%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%201%20%E5%9B%9E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%88%9D%E6%9C%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%94%E5%8D%94%E5%8A%9B%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MQ%20%E2%80%93%20Initial%20code%20loading%20without%20USB%2FUUU%20using%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3ECortex-A53%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%20JTAG%20%E3%81%8A%E3%82%88%E3%81%B3%20JLink%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81segger%20%E3%81%AB%E7%9B%B4%E6%8E%A5%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fforum.segger.com%2Findex.php%2FThread%2F4447-SOLVED-Cortex-A53-support%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fforum.segger.com%2Findex.php%2FThread%2F4447-SOLVED-Cortex-A53-support%2F%3C%2FA%3E%3CBR%20%2F%3ENXP%20%E3%81%AF%E3%80%81Cortex-A53%20%E3%82%B3%E3%82%A2%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%20Lauterbach%20Trace32%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MQ%20%E2%80%93%20Initial%20code%20loading%20without%20USB%2FUUU%20using%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E8%B3%87%E6%96%99%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%20SDK%20%E3%81%A8%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20OpenOCD%20%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%99%E6%98%8E%E7%A2%BA%E3%81%A7%E5%AE%8C%E5%85%A8%E3%81%AA%E4%BE%8B%E3%82%84%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E*%20i.MX8MQ%20(Cortex-A53)%E4%B8%8A%E3%81%AEJTAG%E3%81%8B%E3%82%89DDR%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E*%20JTAG%EF%BC%88%E4%BE%8B%EF%BC%9ASEGGER%20J-Link%E3%82%92%E4%BD%BF%E7%94%A8%EF%BC%89%E7%B5%8C%E7%94%B1%E3%81%A7U-Boot%E3%81%BE%E3%81%9F%E3%81%AF%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92A53%20RAM%E3%81%AB%E7%9B%B4%E6%8E%A5%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%80%82%3C%2FP%3E%3CP%3E*%20%E5%86%85%E9%83%A8%E3%83%96%E3%83%BC%E3%83%88%20ROM%20%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%AB%20(%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81USB%2F%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%AB)%20%E3%81%93%E3%82%8C%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%A5%E6%89%8B%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%20Cortex-M4%E3%82%B3%E3%82%A2%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%A8%E3%81%97%E3%80%81%3C%2FP%3E%3CP%3E*%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3CP%3E*%20%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%81%AB%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%A9%BA%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E5%AE%8C%E5%85%A8%E3%81%AA%E8%B5%B7%E5%8B%95%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81USB%20%E3%81%A8%20UUU%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%81%AB%E3%81%AE%E3%81%BF%E3%80%81JTAG%20%E7%B5%8C%E7%94%B1%E3%81%A7%20U-Boot%20%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ECortex-A53%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%20JTAG%20(USB%20%E3%81%AA%E3%81%97)%20%E7%B5%8C%E7%94%B1%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%85%AC%E5%BC%8F%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E*%20%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%81%AA%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%AC%E3%82%A4%E3%83%89%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%EF%BC%88J-Link%E3%80%81Lauterbach%E3%80%81DS-5%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFOpenOCD%EF%BC%89%3C%2FP%3E%3CP%3E*%20%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81DDR%20%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%80%81JTAG%20%E7%B5%8C%E7%94%B1%E3%81%AE%20A53%20%E8%B5%B7%E5%8B%95%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%97%E3%83%AA%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%95%E3%82%8C%E3%81%9F%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%81USB%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%82%E3%81%AA%E3%81%84%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%94%B9%E3%82%81%E3%81%BE%E3%81%97%E3%81%A6%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MQ%20%E2%80%93%20Initial%20code%20loading%20without%20USB%2FUUU%20using%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%3C%2FP%3E%0A%3CP%3EIDEs%20-%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%83%84%E3%83%BC%E3%83%AB%20(2)%3CBR%20%2F%3E%20SDK_2.3_MX8MQ_%E3%83%99%E3%83%BC%E3%82%BF_%E3%83%91%E3%83%83%E3%83%81(REVSDK2.3_MX8MQ_%E3%83%99%E3%83%BC%E3%82%BF%E7%89%88)%3CBR%20%2F%3E%20(NXP%E3%81%AFi.MX8MQuad%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABIAR%E3%81%A8Segger%E3%83%84%E3%83%BC%E3%83%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F)%3C%2FP%3E%0A%3CP%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Frun-time-software%2Fi.mx-developer-resources%2Fevaluation-kit-for-the-i.mx-8m-applications-processor%3AMCIMX8M-EVK%3Ftab%3DDesign_Tools_Tab%22%20href%3D%22https%3A%2F%2Ftranslate.google.com%2Fwebsite%3Fsl%3Den%26amp%3Btl%3Des%26amp%3Bhl%3Des%26amp%3Bclient%3Dsrp%26amp%3Bu%3Dhttps%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Frun-time-software%2Fi.mx-developer-resources%2Fevaluation-kit-for-the-i.mx-8m-applications-processor%3AMCIMX8M-EVK%3Ftab%253DDesign_Tools_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX%208M%20%E8%A9%95%E4%BE%A1%E3%82%AD%E3%83%83%E3%83%88%7CNXP%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EA53%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8BLauterbach%E3%81%A8Arm%20DS-5%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81OpenOCD%E3%81%A7%E3%81%AFa53%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20class%3D%22link-titled%22%20title%3D%22http%3A%2F%2Ffatalfeel.blogspot.com%2F2015%2F12%2Fopenocd-with-eclipse-debug-kernel-of.html%22%20href%3D%22https%3A%2F%2Ftranslate.google.com%2Fwebsite%3Fsl%3Den%26amp%3Btl%3Des%26amp%3Bhl%3Des%26amp%3Bclient%3Dsrp%26amp%3Bu%3Dhttp%3A%2F%2Ffatalfeel.blogspot.com%2F2015%2F12%2Fopenocd-with-eclipse-debug-kernel-of.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%AC%E3%82%A4%E3%83%89%3A%20OpenOCD%20%2B%20Eclipse%20%2B%20JTAG%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20(Uboot%20%E3%81%8A%E3%82%88%E3%81%B3%20Linux)%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2132594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MQ%20%E2%80%93%20Initial%20code%20loading%20without%20USB%2FUUU%20using%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2132594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E5%86%8D%E9%96%8B%E3%81%BE%E3%81%A7%E4%BB%8A%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3EM4%20%E3%82%B3%E3%82%A2%E3%81%A7%20JTAG%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81Cortex-A53%20%E3%82%B3%E3%82%A2%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%90%8C%E6%A7%98%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EJTAG%20(SEGGER%20J-Link%20%E3%81%AA%E3%81%A9)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Cortex-A53%20%E3%82%B3%E3%82%A2%20(i.MX8MQ)%20%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%85%AC%E5%BC%8F%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%BE%E3%81%9F%E3%81%AF%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2130999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MQ%20%E2%80%93%20Initial%20code%20loading%20without%20USB%2FUUU%20using%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2130999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81JTAG%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%80%81eMMC%20%E3%81%BE%E3%81%9F%E3%81%AF%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E5%80%8B%E5%88%A5%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%20CAN%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
