i.MX8MP: yocto imx-test
1,113 次查看
petertseng
Hi NXP,
I try to install .profile file to /home/root but it always gets overwritten.
The overridden .profile file comes from meta-freescale/recipes-bsp/imx-test/imx-test/memtool_profile
complete -o nospace -C /unit_tests/memtool memtool
Is this a necessary startup test item?
How do I add a custom /home/root/.profile?
1,091 次查看
Zhiming_Liu
Hi @petertseng
it's not a necessary test tool, just a useful tool for dumping registers you want.
You can remove it if you don't need.
1,092 次查看
Zhiming_Liu
Hi @petertseng
1,080 次查看
petertseng
Hi @Zhiming_Liu
Thanks for your reply
Peter Tseng
