Hello ristoH,
The only processor in the i.MX8M extended family with LVDS would be the upcoming i.MX8M Plus, which is still in preproduction. You can find more information on the modules this processor will have available on the following fact sheet:
https://www.nxp.com/docs/en/fact-sheet/IM8MPLUSFS.pdf
Bigger i.MX8 processors like the i.MX8 and i.MX8X do have LVDS modules and may also support parallel CSI. You can find their Fact Sheets below:
https://www.nxp.com/docs/en/fact-sheet/IMX8FAMFS.pdf
https://www.nxp.com/docs/en/fact-sheet/IMX8XFAMFS.pdf
On the 32-bit processor range, some of the larger i.MX6 processors also have LVDS and many others gave parallel camera interfaces, you can see them on the fact sheet for the i.MX6 family on the link below:
https://www.nxp.com/docs/en/fact-sheet/IMX6SRSFS.pdf
I hope this information helps!
