i.MX8M mini 32bit kernel
1,630件の閲覧回数
matt67
I'd like to use the i.MX8M mini with a 32 bit kernel (no multilib), I want to compile the whole system for 32bit only as the Cortex-A53 is capable to run ARM7 or ARM8 instructions.
Is that supported in the implementation of this MPU in Linux BSP ?
タグ(2)
1,496件の閲覧回数
Bio_TICFSL
Hello matt67,
You can Armv7 for 32 bit and Armv8 for 64 bit running on i.MX8Mmini, the following is a guideline how to do it:
https://community.nxp.com/docs/DOC-341031
