i.MX8M Plus SD Card Flash
Wobaffet
Senior Contributor I
I've downloaded android 12.0.0_2.0.0_DEMO_8MP and Linux pre-built images to see how much space does a full build takes on a SD card so we can choose a appropriate eMMC for our custom board. How can I populate an SD card correctly without a board?
Sanket_Parekh
Hi @Wobaffet
I hope you are doing well.
One can try UUU tool to flash the SD card without board. Please refer the below mentioned links.
https://github.com/NXPmicro/mfgtools/releases
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiLl7rrmd36AhWNRmwGHYB4A_EQ...
Thanks & Regards
Sanket Parekh
Sanket_Parekh
Hi @Wobaffet
Thanks & Regards
Sanket Parekh
