i.MX8M Plus Pin Table
2,400 次查看
MPUUser
Is there an excel file with the pin table of i.MX8M Plus that contains all the pin mux information?
Specifically, I want to know all the pins that I can use for the GPTs Capture 1/2 inputs.
I need a couple of capture inputs for my design. Thanks.
2,384 次查看
JorgeCas
Hello, I hope you are doing well.
I suggest you use Config Tools for i.MX to check that information.
2,373 次查看
MPUUser
Hi Jorge,
I try using the tool. The part number is: MIMX8ML8DVNLZAB.
There is only 3 GPT instead of 6 stated in the datasheet. And only GPT1 has 2 capture inputs.
How do I make all the 6 GPTs and the 12 capture inputs show up in the tool? Thanks.
2,362 次查看
JorgeCas
Some of those GPT modules are used by Linux as is mentioned on Linux Reference Manual (Section 2.1.3).
The only GPT modules that can be routed as is mentioned on i.MX reference manual and Config Tools for i.MX are showed on last image.
Best regards.
