i.MX8M Plus Application Processor
1,139 次查看
Dip_2783
Please confirm that i.MX8M Plus processor  'MIMX8ML8DVNLZAB' & ' MIMX8ML8CVNKZAB' are pin to pin compatible. There is only one difference that is regarding end product application.
MIMX8ML8DVNLZAB - Used for Consumer Products
MIMX8ML8CVNKZAB- Used for Industrial Products
Dipesh
1,098 次查看
Chavira
Hi @Dip_2783!
Thank you for contacting NXP Support!
The principal differences are the next:
Both part numbers should be pin to pin compatible.
Best Regards!
Chavira
