i.MX8M Mini i2c setup/hold time specification
已解决
跳至解决方案
1,674 次查看
m_c
Senior Contributor I
Can we use UM10204 as the specification for i.MX8M Mini i2c setup/hold time?
http://nxp.com/doc/um10204
标签 (1)
1 解答
1,586 次查看
Yuri
   According to i.MX8M and i.MX8Mm Datasheets:
The I2C is designed to be compatible with the I2C Bus Specification, version 2.1,
by Philips Semiconductor (now NXP Semiconductors).
https://www.csd.uoc.gr/~hy428/reading/i2c_spec.pdf
Yuri
在原帖中查看解决方案
1 回复
1,587 次查看
Yuri
Yuri
