i.MX8M Mini PCIe end point test
已解决
跳至解决方案
5,229 次查看
m_c
Senior Contributor I
Hardware: i.MX8M Mini customer board
Software: L5.4.47_2.2.0
Customer make their board as an standard PCIe card interface to connect with x86 PC Linux 5.4.68 and follow the PCI Test User Guide <https://www.kernel.org/doc/html/v5.4/PCI/endpoint/pci-test-howto.html> to test i.MX8M Mini PCIe end point function. They found some of test results are fail.
1 解答
5,220 次查看
weidong_sun
Hi Mike,
   I sent some materials about PCIe test , check your email, please!
Have a nice day!
B.R,
Weidong
在原帖中查看解决方案
2 回复数
5,221 次查看
weidong_sun
Hi Mike,
Have a nice day!
B.R,
Weidong
4,708 次查看
robSanders
I am facing the same issue - can you share the work around here or alternatively via email?
