i.MX8 CPU temperature
MinminGu
We use the industrial grade part with Tj max 105C, while the BSP for EVK by default has the commercial grade part, which is only supported up to 95C. We need detail guidance to change the shut down temperature to a higher number.
Rita_Wang
Which product are you using?
dhacker
MIMX8MQ6CVAHZAB
