i.MX8 CPU temperature
1,879件の閲覧回数
MinminGu
We use the industrial grade part with Tj max 105C, while the BSP for EVK by default has the commercial grade part, which is only supported up to 95C. We need detail guidance to change the shut down temperature to a higher number.
1,867件の閲覧回数
Rita_Wang
Which product are you using?
1,362件の閲覧回数
dhacker
MIMX8MQ6CVAHZAB
