i.MX7D JTAG_MOD
i.MX7D JTAG_MOD
1,730 次查看
HOTA
For the i.MX7D's JTAG_MOD, which should be set for the Pull select Field: 100K PU or 100K PD? The datasheet indicates that the default value is 100K PU, but in the config tool, the default value is set to 100K PD. This discrepancy is causing some confusion.
・datasheet
・configtool
HOTA
1,687 次查看
riteshmpatel
Hi @HOTA,
I hope you are doing well.
Apologies for the inconvenience caused.
The Pull Select Field shall be 100K PD. Please refer to the community link given below:
https://community.nxp.com/t5/i-MX-Processors/iMX-7D-JTAG-MOD-default-pulling/td-p/673387
I hope it helps!
Thanks & Regards,
Ritesh M Patel
1,688 次查看
riteshmpatel
Hi @HOTA,
I hope it helps!
Thanks & Regards,
Ritesh M Patel
1,684 次查看
HOTA
Hi @riteshmpatel ,
Thank you for your response.
I apologize for the inconvenience caused as I couldn't find the past articles.
Thank you again!
HOTA
