i.MX7 DDR Rd/Wr Delay Registers
davidgeorge
Can anyone confirm the name of the i.MX7 PHY registers used for DDR Read and Write delay values obtained from the DDR Stress Test tool..
I suspect its DDR_PHY_OFFSET_RD_CON0 and DDR_PHY_OFFSET_WR_CON0
Thank you!
Labels (2)
Yuri
  Correct - DDR_PHY_OFFSET_RD_CON0 and DDR_PHY_OFFSET_WR_CON0.
Yuri
Note: If this post answers your question, please click the Correct
Answer button. Thank you!
Yuri
Yuri
