i.MX6ULL boot config pin input voltage level
1,257 次查看
m_c
Senior Contributor I
In i.MX6ULL, LCD_DATA00~23 are for BOOT_CONFIG pins. If the power group of these pin NVCC_LCD is supplied by 1.8v. The high level input voltage VIH will be 1.8v or 3.3v when booting up?
1,207 次查看
Hi m.c.
if NVCC_LCD power group is supplied by 1.8v, high level will be 1.8v.
1,208 次查看
Hi m.c.
