i.MX6ULL NAND boot question
1,345 次查看
m_c
Senior Contributor I
1. In the Table 8-10 of i.MX6ULL reference manual <http://nxp.com/doc/imx6ullrm>, BOOT_CFG2[4:3] for boot search count. Are 00, 01 both for two boot search count?
2. In the Table 5-7 of i.MX6ULL reference manual <http://nxp.com/doc/imx6ullrm>, there are some reserved pins for NAND boot, like BOOT_CFG2[0]. What is the recommended status for these reserved pins when booting? NC, pull-up, pull-down?
1,260 次查看
AldoG
1.- Yes, you're a correct
2.- You may place a pull-down resistor to this reserved pins, if planning to use fuses please do not burn these, as the behavior may be unpredictable.
Hope this helps,
Aldo.
1,261 次查看
AldoG
Hope this helps,
Aldo.
