i.MX6ULL : Interface 32-bit LPDDR2 memory with processor
988 次查看
sunildhaduk
We want to interface 32-bit LPDDR2 (4Gb) eMCP memory with i.MX6ULL processor.
But i.MX6ULL has only 16-bit memory controller.
Could you please let me know where to terminate unused DQ31-DQ16 data line of LPDDR2 memory and other related control pins (Mask and Data Strobe)?
If we don't connect DQ31-DQ16 data lines of memory than can we still able to use full LPDDR2 memory space (4Gb)?
标记 (1)
843 次查看
igorpadykov
Hi Sunil
please check below link with similar issue
Solved: 32 bit LPDDR2 component with a 16bit controller - Community Forums
