i.MX6S IPU error.
i.MX6S IPU error.
1,657 次查看
satoshishimoda
Senior Contributor I
Hi community,
Our partner have a question about i.MX6S IPU.
When call ioctl:IPU_CHECK_TASK with L3.0.35_4.1.0_ER, return IPU_CHECK_ERR_SPLIT_WITH_ROT error and now work well.
So could you let me know the condition to return IPU_CHECK_ERR_SPLIT_WITH_ROT error?
Satoshi Shimoda
标签 (3)
标记 (1)
1,520 次查看
jimmychan
please see the drivers/mxc/ipu_device.c. You can find the code for ioctl:IPU_CHECK_TASK.
1,521 次查看
jimmychan
