i.MX6 Quad IPU Sensor Interface Signal Mapping
m_c
Senior Contributor I
In table 64 of i.MX6 Q/D data sheet <http://www.nxp.com/files/32bit/doc/data_sheet/IMX6DQCEC.pdf>, it shows the signal mapping of each format.
Is "-" means not connect?
Is "0" means connect to ground?
Tags (2)
christophertele
christophertele
YES!
