Hi Yuri,
Thank you for your prompt reply.
I executed the above commands, but I felt the commands do not show all the resolution.
I think the commands are as below, right?
$ cat /sys/class/graphics/fbx/modes // current assigned resolution
$ cat /sys/class/graphics/fbx/mode // current activated resolution
I want to know all the supported resolution that I can use without any source code modification.
For example, I did not get 800x480@60 by the above commands, but BSP supports this resolution since it supports CLAA-WVGA display.
Satoshi Shimoda
