i.MX6: How to add meta-java for hardknott?
ソリューションへジャンプ
3,808件の閲覧回数
scottikenaga
Currently, there is no hardknott branch for meta-java so how do I add meta-java layer for the hardknott branch. I'm using the latest release, imx-5.10.52-2.1.0 manifest for my i.MX6 custom target board. I need to add openjdk-8 support to my yocto build image.
3,775件の閲覧回数
scottikenaga
For others that come across this thread, my solution was to use the master branch. It works for what I need to do. Probably not the best solution until a Hardknott branch is added for meta-java.
4 返答(返信)
3,806件の閲覧回数
Bio_TICFSL
Hello scottikenaga,
The meta -java still not supported in hardknott branch you can stay in gatesgarth that is 5.10.35 or you can migrate yourself:
https://git.yoctoproject.org/cgit/cgit.cgi/meta-java
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/How-to-add-openjdk-to-Yocto-Layers/ta-p/...
3,802件の閲覧回数
scottikenaga
Do you happen to know what the EOL dates are for NXP's Gatesgarth and Hardknott releases? Can you point me to this info?
We moved to Hardknott since it was a newer release.
Additionally, how are others adding openjdk and java support to NXP's Hardknott release?
Thanks for getting back.
Scott
3,789件の閲覧回数
Bio_TICFSL
Every six months the yocto and kernel are update, there is no opendk to hardknott yet.
3,776件の閲覧回数
scottikenaga
