i.MX6 Development Environment Setup
1,690件の閲覧回数
ddebaun
Is this app note the most up to date guide for setting up a cross-compiling/cross-debugging environment for the i.MX family using Eclipse?
https://www.nxp.com/docs/en/application-note/AN3870.pdf
It seems little old and just wondered if there is anything more current. We're using i.MX6ULL EVK. And is LTIB still a recommended tool to use?
Thanks!
1,678件の閲覧回数
Rita_Wang
Do not recommend to use the LTIB, now we are using the yocto. You can download the new BSP here https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat....
For the Eclipse IDE for Yocto you can refer to https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Setting-up-the-Eclipse-IDE-for-Yocto-App...
