i.MX53 VPU decoding behavior
torus1000
Contributor V
I want to know the i.MX53 VPU decoder output when inputs non-standard frame.
If somebody knows this, please answer my following questions.
(Q) For instance, sequence start at P-frame, does VPU ignore P/B-frame and output nothing?
(Q) If not correct, what kind of decoded data outputs?
Thanks.
Labels (2)
Tags (2)
qiang_li-mpu_se
The VPU can decode P/B-frame too, but the sequence should follow the video specification.
karina_valencia
NXP Apps Support
NXP Apps Support
Qiang_FSL are you able to check this case?
