i.MX53 VPU decoding behavior
1,738件の閲覧回数
torus1000
I want to know the i.MX53 VPU decoder output when inputs non-standard frame.
If somebody knows this, please answer my following questions.
(Q) For instance, sequence start at P-frame, does VPU ignore P/B-frame and output nothing?
(Q) If not correct, what kind of decoded data outputs?
Thanks.
ラベル(2)
タグ(2)
1,579件の閲覧回数
qiang_li-mpu_se
The VPU can decode P/B-frame too, but the sequence should follow the video specification.
1,579件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
Qiang_FSL are you able to check this case?
