i.MX53 VPU decoder output timing
1,103 次查看
torus1000
Hi Chip experts,
I have a quesion when i.MX53 VPU decoded data write to the frame buffer.
Which timing is correct?
a)  data wrote per each microblock decoded
b)  or data wrote only when whole frame decoded
Thanks.
标记 (1)
999 次查看
joanxie
The VPU has an internal DSP called the BIT processor which controls the internal hardware blocks for
video decoder operations.
The BIT processor completes decoding operations on a frame-by-frame basis, which allows low level
independency of VPU operations to the host processor
1,000 次查看
joanxie
