i.MX51 Android BSP make Error
1,757 次查看
HitoshiOgasawar
Dear Sir,
I'm having problems with an error of Android BSP of "i.MX51" and "make" run.
The patched the "R10.3", we have to "R10.3.1" Android BSP.
Error occurs is as follows.
Please tell me someone an idea to solve this.
hardware/alsa_sound/AudioHardwareALSA.cpp:349: error: 'DEVICE_OUT_WIRED_HDMI' is not a member of 'android::AudioSystem'
hardware/alsa_sound/AudioHardwareALSA.cpp: In member function 'virtual android::AudioStreamIn* android::AudioHardwareALSA::openInputStream(uint32_t, int*, uint32_t*, uint32_t*, android::status_t*, android::AudioSystem::audio_in_acoustics)':
hardware/alsa_sound/AudioHardwareALSA.cpp:397: error: 'DEVICE_OUT_WIRED_HDMI' is not a member of 'android::AudioSystem'
make: *** [out/target/product/imx51_bbg/obj/SHARED_LIBRARIES/libaudio_intermediates/AudioHardwareALSA.o] Error 1
Jin.
标记 (2)
4 回复数
1,657 次查看
YixingKong
Senior Contributor IV
Hitoshi
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
1,657 次查看
YixingKong
Hitoshi
We have not got your response yet and will close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
1,657 次查看
YixingKong
Hitoshi
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
1,657 次查看
weidong_sun
Hello,hitoshi,
     I tested R10.3/R10.3.1, But I didn't reproduce the issue you met.
     The final android BSP version we released for i.mx51 & i.mx53 is R10.4 , whose android version is ver2.3.7. This version is stable. So I suggest you had better use R10.4 for your design.
Weidong
