i.MX27 MfgTool and Bulk-IO driver
2,077 次查看
siwoolee
Hi.
I want to download firmware to i.MX27 custom board with MfgTool on the Win 7.
but I meet fail message when I connect usb cable to PC with i.MX27 OTG.
Is there any way to do?
Firstly, I really want to connect i.MX27 as a Bulk-IO device driver on the Win 7.
Best regards.
标记 (2)
1,827 次查看
joanxie
There’s no any version of mfgtool can support MX27. I suggest that you can Use Virtual Machine in Win7 to install a WinXP then use ATK tools.
1,827 次查看
siwoolee
Thank you for your reply.
I've been using ATK tools on the Window XP PC. but I failed to run ATK tool on the Window 7 PC.
As you know, ATK tools need Window 2000 or XP platform.
so, I want to make MfgTool downloading i.MX7 image on the Window 7 platform.
Firstly, I meet device driver issue on the Window 7 platform with i.MX27 download mode.
1,828 次查看
joanxie
1,827 次查看
joanxie
for imx27, why don't you use ATK tools?
i.MX27 Processors|Robust Security for Mobile|NXP
youc an download ATK tools, which can download image to mx27 board. and install on the windows.
