i.MX in OpenEmbedded/Yocto - wall comments
OtavioSalvador
Senior Contributor II
Please use the mailing list to communicate for easy sharing of information. More information bellow
Mailing list: http://groups.google.com/group/meta-fsl-arm
Source code: https://github.com/Freescale/meta-fsl-arm
adrian_alonso
We are proud to announce the creation of a mailing list to easy the communication of people using Freescale’s ARM processors and micro-controllers with OpenEmbedded and/or Yocto. For now, we will be using Google Groups for this task. You can join the group at http://groups.google.com/group/meta-fsl-arm
This mailing list will be used to share work and review the patches before those are merge onto the BSP layer. The layer itself has also been moved to a new repository, still at GitHub. The new repository http://github.com/Freescale/meta-fsl-arm; people already using previous meta-freescale GitHub trees you will need to change their GIT configuration to this new location.
Please join us at the mainling list and start to watch and to fork the repository at GitHub.
