how to write spi dma driver on non-OS environment
1,097件の閲覧回数
jackyliu
customer wrote the driver on non-OS environment. But the DMA can't be triged.
Original Attachment has been moved to: 353-spi.c
960件の閲覧回数
jackyliu
I checked their codes, and found they don't trig DMA.
Below is my instruction:
In our mxs_spi_handle_message(), it call mxs_spi_setup_transfer() to setup spi speed. So you need to ask the customer to check if their spi speed is set correctly or not.
Then mxs_spi_handle_message() call
At the last , it call mxs_spi_txrx_dma().
