[i.MX 8MN DDR4] how to build rootfs, kernel and how to flash rootfs, kernel image
bryan_hong
Senior Contributor I
Hello
I execute 'bitbake fsl-image-af-littlekernel' but below file did not re-generated.
   - fsl-image-af-littlekernel-imx8mnddr4ab2-20210814061807.rootfs.wic.bz2
how to re-generate rootfs file?
and let me know how to build only kernel image, and how to flash that kernel image to evk kit.
thanks
Bryan
bryan_hong
@igorpadykov The documentation you mentioned doesn't explain how to update rootfs in detail.
Re-generate rootfs
bitbake -c cleansstate fsl-image-af-littlekernel
Kernel modify, build, flash
bitbake -c compile -f linux-imx
bitbake linux-imx
I think the above should be a guide.
bryan_hong
Re-generate rootfs
bitbake linux-imx
Hi Hong
for building and programming procedures one can refer to     i.MX Yocto Project User’s Guide​
i.MX Linux User’s Guide​
