Hi @DanielDs,
I hope you are doing well.
All VSS pins are internally connected to each other. However, it is highly recommended to connect all VSS pins to the GND since there may be the possibility of a long current return path due to not connecting the VSS pin.
Thanks & Regards,
Ritesh M Patel
