i.MX 8M Mini ISL79987 Video Issue
1,551 次查看
cbl
Contributor V
I'm working on the i.MX 8M Mini platform.
I have activated the ISL79987 Video Decoder IC.
Although the IC is 4-Channel, I see "video0", "video1", and "video2" under the "/dev" directory.
I am using the following configuration as DTS.
     isl7998x_mipi@3d {
        compatible = "isil,isl79987";
        reg = <0x3d>;
        ports {
          #address-cells = <1>;
          #size-cells = <0>;
          port@0 {
            reg = <0>;
            isl79987_out: endpoint {
              remote-endpoint = <&mipi_csi2_in>;
              data-lanes = <1>;
          port@1 {
            reg = <1>;
            endpoint {
              /*remote-endpoint = <&camera_0>;*/
          port@2 {
            reg = <2>;
            endpoint {
              /*remote-endpoint = <&camera_1>;*/
          port@3 {
            reg = <3>;
            endpoint {
          port@4 {
            reg = <4>;
            endpoint {
Could you help me with this issue?
1,509 次查看
Bio_TICFSL
1,479 次查看
cbl
Contributor V
Thank you for your support.
I have looked through this page but could not find the solution.
How do I update my device tree so that I can see 4 channels of video under /dev directory?
Can you please help me with this?
Best regards.
