httpd.conf settings
httpd.conf settings
2,196件の閲覧回数
davidzhou
Contributor V
Hi ,
I have imx6ul dev board.
I started apache2 httpd as
httpd -h /home/www
it runs great. But how to setup a default page such as index.html, or index.php, or default.html?
I googled and found some information regarding this. But anything I add into the httpd.conf, such as
<IfModule dir_module>     DirectoryIndex index.html index.php   </IfModule>
I got config error message, with the command
httpd -c httpd.conf
What did I miss?
Thank you,
David Zhou
ラベル(2)
3 返答(返信)
2,047件の閲覧回数
jimmychan
2,047件の閲覧回数
davidzhou
Contributor V
Thanks, Jimmy. I think I may have a different yocto version. When I added apache2 through PACKAGECONFIG_append, I don't have etc/httpd folder and files. I have to dig into it.
David Zhou
2,047件の閲覧回数
davidzhou
Contributor V
I added IMAGE_INSTALL_append = "apache2"
works
David
