how to user build kernel file.. for android 10 OS
Ruban1
how to user build kernel file.. for android 10 OS.
when i checked android_build/kernel/ only prebuild is avaliable.. due to this i am not able to add drivers or access the gpios  in Android 10 OS.
i want to build complete kernel file as user build not using pre build.
and i want to link the drivers which i create in kernel .And allow access all the gpio and peripherial
Zhiming_Liu
The way of building kernel is same as yocto , you can refer to i.MX_PORTING.pdf
