how to set our custom board settings in DDR config tool.
1,239 次查看
arka
I am trying to create lpddr4x_timing.c for our custom board , to add two FSP support . please help us to create a lpddr4x_timing.c file for our custom board , and how to use DDR config tool to create lpddr4x_config.c file to add custom board settings on DDR config tool?
4 回复数
1,212 次查看
JorgeCas
This can be done through DDR tool in Config Tools for i.MX. You need to enter your memory features and this will generate a initialization/timing script for DDR configuration. If you need to change some register value, you can do it in this generated scripts.
Config Tools for i.MX Applications Processors | NXP Semiconductors
Here you can consult more information about how to use the tool:
User Guide for Config tools for i.MX
And here how to implement it in software in section 4.5 Building u-boot image:
MScale DDR tool
Best regards.
1,207 次查看
arka
Hi jorge,
We need to use User Guide for Config Tools for i.MX
this link document to create lpddr4x_timing.c file , in which section we need to refer,
We have our custom board yocto build, we need to add FSP support on lpddr4x_timing.c file, adding two FSP support on IMX93.
标记 (1)
1,190 次查看
JorgeCas
Please refer to section 6 DDR Tool.
With FSP are you referring to frequency set point?
Best regards.
1,237 次查看
arka
We have using IMX93 custom board.
标记 (1)
