- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello everyone,
I want to add RTC function to imx8 maaxboard,
We used another board with SPI interface and rtc chip M41T93RMY6F on the motherboard.
I found that there is a kernel driver file for the chip M41T93RMY6F.
and so
problem:
1.
I need to configure the kernel to select spi rtc M41T93RMY6F support, right?
So after the kernel is configured, should spi rtc work properly?
2. After the kernel is started, how to configure or read/set the time or date in the user space?
3. Or directly use hwclock command to set/read rtc? No other settings or configurations are needed after the kernel is started?
4. Any user space application source code?
thank you very much.
解決済! 解決策の投稿を見る。
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
hi
step 1
I have successfully added the rtc spi m41t39 in maaxbaord.
237 pinctrl_ecspi1: ecspi1grp {
238 fsl,pins = <
239 MX8MQ_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x16
240 MX8MQ_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI 0x16
241 MX8MQ_IOMUXC_ECSPI1_MISO_ECSPI1_MISO 0x16
242 MX8MQ_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK 0x1816
243 >;
244 };
&ecspi1{
fsl,spi-num-chipselects = < 1 >;
cs-gpios = <&gpio5 9 0 > ;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ecspi1 >;
status = "okay";
#address-cells=<1>;
#size-cells=<0>;
rtc@0x00{
#address-cellss=<1>;
#size-cells=<1>;
compatible = "rtc-m41t93";
spi-max-frequency = <5000000>;
reg = <0>;
step 2. config m41t39 in kernel config.
NOT use module, need to build in kernel. because if use module. every time after kernel start up, the module should insert and the time should reset again so that it seems does not work.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I got some doc from technical supporter:
and changed dts as below:
238 fsl,pins = <
243 >;
244 };
&ecspi1{
cs-gpios = <&gpio5 13 0 > ;
status = "okay";
#address-cells=<1>;
#size-cells=<0>;
rtc@0x00{
#size-cells=<1>;
spi-max-frequency = <20000000>;
reg = <0>;
but error:
dmesg | grep rtc
[ 1.038658] imx-drm display-subsystem: bound imx-dcss-crtc.0 (ops dcss_crtc_ops)
[ 2.414482] rtc-m41t93 spi0.0: rtc core: registered rtc-m41t93 as rtc0
[ 2.422484] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs-rtc-lp as rtc1
[ 2.894506] rtc-m41t93 spi0.0: hctosys: unable to read the hardware clock
I am at sure how to register SPI rtc driver, in the driver file : the .name =rtc-m41t93. but there is not "compatible"
any suggestions?
Thank you.
attached file is reference file from maxxbaord
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi jin1
nxp has special service for helping customers with software porting :
https://contact.nxp.com/new-prof-svcs-sw-tech
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi jin1
for external rtc examples one can look at below link
https://variwiki.com/index.php?title=IMX_RTC
https://github.com/varigit/linux-imx/blob/imx_4.19.35_1.1.0_var01/arch/arm/boot/dts/imx6q-var-dt6cus...
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
another thing:
the new forum is not convenient than before. after you replied, I can not received in my email new. before I could received replying every time.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I read your posted help doc.
it's not for Imx8mq.
I do not find simliar RTC node in imx8qm device tree in maaxboard(em-sbc-imx8m.dts) or imx8mq-evk board(fsl-imx8mq-evk.dts)
I asked the technical supporter ,and get the pin
J10 in board in maaxboard
original GPIO processor ball SPI function (another ball No. from different Doc, maybe wrong)
19 GPIO3_IO06 G20 ECSSPI1_MOSI. A4
21 GPIO3_IO07. J20 ECSSPI1_MISO B4
23 GPIO3_IO00 G19 ECSSPI1_SCLK D5
24 GPIO3_IO01 H19 ECS SPI1_SS0 D4
I am another sure how to add SPI node in device tree.
any more help?
attched is em-sbc-imx8m.dts file
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi jin1
i.MX8MQ has ecspi, i2c modules similar to i.MX6 series. So modifications
can be performed in the same way.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I find a patch at here:
should be work for SPI? please have a look.
I am going to try.
Thank you
https://patchwork.kernel.org/patch/10782611/
diff --git a/arch/arm64/boot/dts/freescale/imx8mq.dtsi b/arch/arm64/boot/dts/freescale/imx8mq.dtsi
index 892063a7c26c..45b9d4a8b0da 100644
--- a/arch/arm64/boot/dts/freescale/imx8mq.dtsi
+++ b/arch/arm64/boot/dts/freescale/imx8mq.dtsi
@@ -26,6 +26,9 @@
serial1 = &uart2;
serial2 = &uart3;
serial3 = &uart4;
+ spi0 = &ecspi1;
+ spi1 = &ecspi2;
+ spi2 = &ecspi3;
ckil: clock-ckil {
@@ -381,6 +384,42 @@
#size-cells = <1>;
ranges = <0x30800000 0x30800000 0x400000>;
+ ecspi1: spi@30820000 {
+ #address-cells = <1>;
+ #size-cells = <0>;
+ compatible = "fsl,imx8mq-ecspi", "fsl,imx51-ecspi";
+ reg = <0x0 0x30820000 0x0 0x10000>;
+ interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>;
+ clocks = <&clk IMX8MQ_CLK_ECSPI1_ROOT>,
+ <&clk IMX8MQ_CLK_ECSPI1_ROOT>;
+ clock-names = "ipg", "per";
+ status = "disabled";
+ ecspi2: spi@30830000 {
+ reg = <0x0 0x30830000 0x0 0x10000>;
+ interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>;
+ clocks = <&clk IMX8MQ_CLK_ECSPI2_ROOT>,
+ <&clk IMX8MQ_CLK_ECSPI2_ROOT>;
+ ecspi3: spi@30840000 {
+ reg = <0x0 0x30840000 0x0 0x10000>;
+ interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>;
+ clocks = <&clk IMX8MQ_CLK_ECSPI3_ROOT>,
+ <&clk IMX8MQ_CLK_ECSPI3_ROOT>;
uart1: serial@30860000 {
compatible = "fsl,imx8mq-uart",
"fsl,imx6q-uart";
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I am trying to add it
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
add something like this: in fsl-imx8mq.dtsi
right?
784 ecspi1: ecspi@30820000 {
785 compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi";
786 reg = <0x0 0x30820000 0x0 0x10000>;
787 interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>;
788 clocks = <&clk IMX8MQ_CLK_ECSPI1_ROOT>,
789 <&clk IMX8MQ_CLK_ECSPI1_ROOT>;
790 clock-names = "ipg", "per";
791 status = "okay";
792 rtc@68 {
793 compatible = "rtc-m41t93";
794 reg = <0x68>;
795 };
796
797 };
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
test results using the rtc node as upper
-sh-4.4# dmesg | grep rtc
[ 1.043095] imx-drm display-subsystem: bound imx-dcss-crtc.0 (ops dcss_crtc_ops)
[ 2.045533] spi_master spi0: /ecspi@30820000/rtc@68 has no valid 'spi-max-frequency' property (-22)
[ 2.054696] spi_master spi0: Failed to create SPI device for /ecspi@30820000/rtc@68
[ 2.435732] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs-rtc-lp as rtc0
[ 2.883123] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:00 UTC (0)
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
my dts for spi rtc
I used your reference file and changed(add) dts in em-sbc-imx8m.dts
as below:
238 fsl,pins = <
243 >;
244 };
&ecspi1{
status = "okay";
#address-cells=<1>;
#size-cells=<0>;
rtc@0x00{
#size-cells=<1>;
reg = <0>;
but error:
dmesg | grep rtc
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
hi
step 1
238 fsl,pins = <
243 >;
244 };
&ecspi1{
status = "okay";
#address-cells=<1>;
#size-cells=<0>;
rtc@0x00{
#size-cells=<1>;
reg = <0>;
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Can you explain how to edit the the DTS file
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
see attached 001-spi-real-time-M41T93.patch patch file or following,you can compare with the original kernel file. you will get it how to edit the the DTS file.
the original kernel file is here https://github.com/Avnet/meta-maaxboard zeus branch(master branch) for maaxboard. after you bitbake building, you can get the kernel source code.
or here ,the kernel source code (just the default branch) https://github.com/Avnet/linux-imx
index 5943d2ed653d..239271911429 100755
@@ -826,7 +826,7 @@
#size-cells = <0>;
- compatible = "fsl,imx8mq-ecspi", "fsl,imx6ul-ecspi";
reg = <0x30820000 0x10000>;
@@ -838,7 +838,7 @@
#size-cells = <0>;
reg = <0x30830000 0x10000>;
@@ -850,7 +850,7 @@
#size-cells = <0>;
reg = <0x30840000 0x10000>;
diff --git a/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi b/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi
index 25c84d58bf74..61202110b358 100755
--- a/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi
+++ b/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi
@@ -37,10 +37,10 @@
fsl,pins = <
- MX8MQ_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x16
- MX8MQ_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI 0x16
- MX8MQ_IOMUXC_ECSPI1_MISO_ECSPI1_MISO 0x16
- MX8MQ_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK 0x1816
+ MX8MQ_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x19
+ MX8MQ_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI 0x19
+ MX8MQ_IOMUXC_ECSPI1_MISO_ECSPI1_MISO 0x19
+ MX8MQ_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK 0x19
@@ -89,11 +89,23 @@
&ecspi1{
- fsl,spi-num-chipselects = < 1 >;
- cs-gpios = <&gpio5 13 0 > ;
- pinctrl-0 = <&pinctrl_ecspi1 >;
+ pinctrl-0 = <&pinctrl_ecspi1>;
+ fsl,spi-num-chipselects = <1>;
+ cs-gpios = <&gpio5 9 GPIO_ACTIVE_HIGH>;
status = "okay";
+ rtc@0 {
+ compatible = "rtc-m41t93";
+ reg = <0>;
+ spi-max-frequency = <5000000>;
+&snvs_rtc {
&i2c2 {
diff --git a/arch/arm64/configs/maaxboard_defconfig b/arch/arm64/configs/maaxboard_defconfig
index a89ebacf02f7..0a796e196774 100755
--- a/arch/arm64/configs/maaxboard_defconfig
+++ b/arch/arm64/configs/maaxboard_defconfig
@@ -659,6 +659,7 @@ CONFIG_EDAC=y
CONFIG_EDAC_GHES=y
CONFIG_EDAC_SYNOPSYS=y
CONFIG_RTC_CLASS=y
+CONFIG_RTC_DRV_M41T93=y
CONFIG_RTC_DRV_DS1307=y
CONFIG_RTC_DRV_MAX77686=y
CONFIG_RTC_DRV_RK808=m
diff --git a/drivers/dma/imx-sdma.c b/drivers/dma/imx-sdma.c
index 09ae4282ad56..a145004f649b 100644
--- a/drivers/dma/imx-sdma.c
+++ b/drivers/dma/imx-sdma.c
@@ -639,7 +639,6 @@ static struct sdma_driver_data sdma_imx8mq = {
.num_events = 48,
.script_addrs = &sdma_script_imx7d,
.check_ratio = 1,
- .ecspi_fixed = true,
static struct sdma_driver_data sdma_imx8mp = {
diff --git a/drivers/spi/spi-fsl-lpspi.c b/drivers/spi/spi-fsl-lpspi.c
index 39870bc38e40..f608f89f45cd 100644
--- a/drivers/spi/spi-fsl-lpspi.c
+++ b/drivers/spi/spi-fsl-lpspi.c
@@ -888,12 +888,6 @@ static int fsl_lpspi_probe(struct platform_device *pdev)
controller->bus_num = pdev->id;
controller->slave_abort = fsl_lpspi_slave_abort;
- ret = devm_spi_register_controller(&pdev->dev, controller);
- if (ret < 0) {
- dev_err(&pdev->dev, "spi_register_controller error.\n");
- goto out_controller_put;
if (!fsl_lpspi->is_slave) {
controller->cs_gpios = devm_kzalloc(&controller->dev,
sizeof(int) * controller->num_chipselect, GFP_KERNEL);
@@ -901,6 +895,11 @@ static int fsl_lpspi_probe(struct platform_device *pdev)
for (i = 0; i < controller->num_chipselect; i++) {
int cs_gpio = of_get_named_gpio(np, "cs-gpios", i);
+ if (cs_gpio == -EPROBE_DEFER) {
+ ret = -EPROBE_DEFER;
+ goto out_controller_put;
if (!gpio_is_valid(cs_gpio) && lpspi_platform_info)
cs_gpio = lpspi_platform_info->chipselect[i];
@@ -971,13 +970,30 @@ static int fsl_lpspi_probe(struct platform_device *pdev)
ret = fsl_lpspi_dma_init(&pdev->dev, fsl_lpspi, controller);
if (ret == -EPROBE_DEFER)
+ goto err_disable_runtime_pm;
if (ret < 0)
dev_err(&pdev->dev, "dma setup error %d, use pio\n", ret);
+ else
+ /* disable LPSPI module IRQ when enable DMA mode successfully,
+ * to prevent the unexpected LPSPI module IRQ events*/
+ disable_irq(irq);
+ ret = devm_spi_register_controller(&pdev->dev, controller);
+ if (ret < 0) {
+ dev_err(&pdev->dev, "spi_register_controller error.\n");
+ pm_runtime_mark_last_busy(fsl_lpspi->dev);
+ pm_runtime_put_autosuspend(fsl_lpspi->dev);
return 0;
+err_disable_runtime_pm:
+ pm_runtime_dont_use_autosuspend(fsl_lpspi->dev);
+ pm_runtime_put_sync(fsl_lpspi->dev);
+ pm_runtime_disable(fsl_lpspi->dev);
out_controller_put:
spi_controller_put(controller);
diff --git a/drivers/spi/spi-imx.c b/drivers/spi/spi-imx.c
index 91e32291c44e..0128e33eb5bc 100644
--- a/drivers/spi/spi-imx.c
+++ b/drivers/spi/spi-imx.c
@@ -1775,8 +1775,13 @@ static int spi_imx_probe(struct platform_device *pdev)
/* Request GPIO CS lines, if any */
if (!spi_imx->slave_mode && master->cs_gpios) {
for (i = 0; i < master->num_chipselect; i++) {
- if (!gpio_is_valid(master->cs_gpios[i]))
+ if (!gpio_is_valid(master->cs_gpios[i])) {
+ if (master->cs_gpios[i] == -EPROBE_DEFER) {
+ goto out_spi_bitbang;
continue;
ret = devm_gpio_request(&pdev->dev,
master->cs_gpios[i],
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I in my case i am trying to just access the spi module that is connected to maaxboard mini.
spidev is not getting listed in /dev
i have added the device tree for it as follows
&ecspi1 {
fsl,spi-num-chipselects = <4>;
cs-gpios = <&gpio5 9 0>;
status = "okay";
after this
dmesg |grep spi
[ 1.392663] spi_imx 30820000.spi: probed
Kernel configuration:
CONFIG_SPI_IMX=y
CONFIG_SPI=y compiled into the kernel,
CONFIG_SPI=m compile as a loadable module
both tried
CONFIG_SPI=y nothing was visual but spi is expected to be supported from kernel
in the second case spidev.ko was found in the
cd /lib/modules/5.4.24-2.1.0+gb8e6bda2e31d/kernel/drivers/spi path
still /dev/ doesnot list spidev0.0... or any spidev
i tried to manually mknod the spidev1.0 and spidev1.1 and try to open the file.. this gave cant open error.
what is it that i am missing
@gonewithwind-peter
@igorpadykov
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I checked my maaxboard mini zeus branch (linux 5.4), I think spi should work well ,do not need to patch it. for my rtc spi chip ,I only add my rtc chip there, I think the default spi with default kernel config should work. what chip do you want to connect the spi1 ?
I see you patched something at & ecspi 1, but I see my patch for my rtc chip, I never modified there. I keep there as default.
&ecspi1 {
status = "okay";
see my attached file as below:
cat 002-rtc-m41t93.patch
diff -Naur ori/arch/arm64/boot/dts/freescale/imx8mm.dtsi patch-2/arch/arm64/boot/dts/freescale/imx8mm.dtsi
--- ori/arch/arm64/boot/dts/freescale/imx8mm.dtsi 2021-09-03 10:47:15.651358472 -0400
+++ patch-2/arch/arm64/boot/dts/freescale/imx8mm.dtsi 2021-09-03 14:25:44.549574600 -0400
@@ -704,15 +704,6 @@
compatible = "fsl,sec-v4.0-mon","syscon", "simple-mfd";
reg = <0x30370000 0x10000>;
- snvs_rtc: snvs-rtc-lp {
- compatible = "fsl,sec-v4.0-mon-rtc-lp";
- regmap = <&snvs>;
- offset = <0x34>;
- interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>,
- <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
- clocks = <&clk IMX8MM_CLK_SNVS_ROOT>;
- clock-names = "snvs-rtc";
snvs_pwrkey: snvs-powerkey {
compatible = "fsl,sec-v4.0-pwrkey";
@@ -850,7 +841,7 @@
dmas = <&sdma1 0 7 1>, <&sdma1 1 7 2>;
dma-names = "rx", "tx";
- status = "disabled";
+ status = "enabled";
diff -Naur ori/arch/arm64/boot/dts/freescale/maaxboard-mini-extended-gpio.dtsi patch-2/arch/arm64/boot/dts/freescale/maaxboard-mini-extended-gpio.dtsi
--- ori/arch/arm64/boot/dts/freescale/maaxboard-mini-extended-gpio.dtsi 2021-09-03 10:46:33.255550169 -0400
+++ patch-2/arch/arm64/boot/dts/freescale/maaxboard-mini-extended-gpio.dtsi 2021-09-03 14:28:33.752814424 -0400
@@ -101,6 +101,13 @@
pinctrl-0 = <&pinctrl_ecspi1 &pinctrl_ecspi1_cs>;
status = "okay";
+rtc@0{
+ #address-cellss=<1>;
+ #size-cells=<1>;
+ reg = <0>;
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I used bitbake -c menuconfig linux-imx to check the kernel config , I can not find the keyword "TMC429" . that means there is no TMC429 (motor chip) driver in the kernel to support it.
it is not like my rtc chip rtc-m41t93 , I can find it and can find rtc-m41t93.c driver so that I enabled it in kernel and then add my patch in dtb,after that my rtc can work .
so you can not use my solution to connect the TMC429 to spi .that means you can not patch like mine:
+rtc@0{
+ #size-cells=<1>;
+ reg = <0>;
so that you can not use the layer driver (like my rtc) to operate your TMC429. you need to use more lower spi driver (generic driver) to operate it.
so I suggest ,you keep all the spi as default in DTB (device tree) because my rtc chip works well with the default lower spi driver and I never modified(patched) it. so try to find how to directly operate the lower spi driver.
sorry, I have no more experience to operate it, please search online or some one else can help you here.
Maybe you can user space driver (normal linux C code) not kernel driver to operate spi . because it seems there is no kernel driver after checking with bitbake -c menuconfig linux-imx
I searched online with "how to directly read /write spi in linux user space"
results:
The most popular way for SPI read/write in user space is through character device /dev/spidev but this way gives you only half-duplex access. An other way for SPI read/write in user space is through ioctl SPI_IOC_MESSAGE(N) request that gives you full-duplex access.
https://stackoverflow.com/questions/36626214/can-i-select-on-a-dev-spidev-file-descriptor
Maybe it can hep you
