how to enable realtek wifi module on imx6q in android 4.3
984 次查看
conteczxy
I am working on imx6q in android 4.3, and I want to port realtek wifi module, such as 8188eu and 8192cu.
does any body have any document about that? realtek official site only provide 4.1 and 4.2 porting steps, but no 4.3 steps, and I tried 4.2 steps in 4.3, it doesn't work, and met some problems I didn't find any solution to it.
my driver is ok, and iwlist iwconfig can make wifi module work, but android ui doesn't work.
Any suggestion is appreciated,
Thanks.
标签 (2)
标记 (2)
794 次查看
BiyongSUN
The driver in android including framework.
The vendor like realtek will provide entire package for the android.
Please check with them. and don't forget to provide accurate android version you are using. They will help you.
