As known Ethernet is supported under different media, in particular
there is Fiber Interface in 100BASE-FX.
Please look at section 5.2.1.2 (Fiber Interface) of classical transceiver LXT971A.
< http://cortina-systems.com/products/download/398 >
General information may be found here :
< http://cortina-systems.com/products/download/165 >
So, two solutions may be considered when using i.MX28 ENET with optic media :
1) special PHY(+Fiber Optic Transceiver) between MAC (MII) and optic media ;
2) media converter between electrical and optic media.
Note, the LXT971A, mentioned above, supports both standards 100BASE-FX
and 100BASE-TX.
As for media converters, please take a look at the following :
< http://www.perle.com/products/SFP-Media-Converter.shtml?utm_source=google&utm_medium=cpc&utm_campaig... >
Another (on board chip) approach is as following :
< http://www.digchip.com/datasheets/parts/datasheet/028/AL211-pdf.php >
