how do i solve build error about imx-optee-client?
6,242件の閲覧回数
afv2000
currently, OPTEE_CLIENT_SRC address change to
"https://github.com/nxp-imx/imx-optee-client.git;protocol=https"
in optee-client_3.2.0.imx.bb
but when i partial build about optee-client, build version is  changed to 3.7.0
and build error is below.
ERROR: Logfile of failure stored in: /home/worker/WAVE_MAIN/build_high/tmp/work/aarch64-poky-linux/optee-client/3.7.0.imx-r0/temp/log.do_compile.10604
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 8 O=/home/worker/WAVE_MAIN/build_high/tmp/work/aarch64-poky-linux/optee-client/3.7.0.imx-r0/build -C /home/worker/WAVE_MAIN/build_high/tmp/work/aarch64-poky-linux/optee-client/3.7.0.imx-r0/git ARCH=arm64 CFG_TEE_FS_PARENT_PATH=/var/optee/tee
| make: Entering directory '/home/worker/WAVE_MAIN/build_high/tmp/work/aarch64-poky-linux/optee-client/3.7.0.imx-r0/git'
| make: *** No targets specified and no makefile found. Stop.
when i checkd optee-client_3.7.0.imx.bb, there is no especial command
# Copyright (C) 2019-2020 NXP
require optee-client.imx.inc
SRCBRANCH = "imx_5.4.3_2.0.0"
SRCREV = "bc0ec8ce1e4dc5ae23f4737ef659338b7cd408fe"
how do i fix this issue?
タグ(2)
5,899件の閲覧回数
afv2000
final answer.
in the optee-client_3.2.0.imx.bb
from
OPTEE_CLIENT_SRC ?= "git://source.codeaurora.org/external/imx/imx-optee-client.git;protocol=https"
SRC_URI = "${OPTEE_CLIENT_SRC};branch=${SRCBRANCH}"
to
OPTEE_CLIENT_SRC ?= "git://github.com/nxp-imx/imx-optee-client.git"
SRC_URI[md5sum]= "965bc1e91a14762841ac47007b53d5d8"
13 返答(返信)
6,167件の閲覧回数
afv2000
when i cleanall several times and build again, error log was changed.
bitbake -c cleanall optee-client
bitbake  optee-client
error log
WARNING: optee-client-3.7.0.imx-r0 do_fetch: Renaming /home/worker/WAVE_MAIN/downloads/imx-optee-client.git to /home/worker/WAVE_MAIN/downloads/imx-optee-client.git_bad-checksum_6c979c117104742e26660040468117ce
WARNING: optee-client-3.7.0.imx-r0 do_fetch: Checksum failure encountered with download of https://github.com/nxp-imx/imx-optee-client.git;protocol=https;branch=imx_5.4.3_2.0.0 - will attempt other sources if available
ERROR: optee-client-3.7.0.imx-r0 do_fetch: Fetcher failure for URL: 'https://github.com/nxp-imx/imx-optee-client.git;protocol=https;branch=imx_5.4.3_2.0.0'. Checksum mismatch!
File: '/home/worker/WAVE_MAIN/downloads/imx-optee-client.git' has md5 checksum 6c979c117104742e26660040468117ce when cb0cc3102e77261d29d2d8d25fd8bee6 was expected
If this change is expected (e.g. you have upgraded to a new version without updating the checksums) then you can use these lines within the recipe:
SRC_URI[md5sum] = "6c979c117104742e26660040468117ce"
SRC_URI[sha256sum] = "8db6329562ec41dec5e3c7fb08cd911401f3324eda241410d7b95b323ccde7b8"
Otherwise you should retry the download and/or check with upstream to determine if the file has become corrupted or otherwise unexpectedly modified.
but when i add checksum in optee-client_3.7.0.imx.bb like below
SRC_URI[md5sum] = "cb0cc3102e77261d29d2d8d25fd8bee6"
it is cause of another error
ERROR: optee-client-3.7.0.imx-r0 do_fetch: Fetcher failure for URL: 'https://github.com/nxp-imx/imx-optee-client.git;protocol=https;branch=imx_5.4.3_2.0.0'. Unable to fetch URL from any source.
so i am finding the right location inserting  SRC_URL checksum
6,110件の閲覧回数
joanxie
as I mentioned before, how about don't change the bb file to the github, it seems couldn't get the source from this link, no matter how you delete and rebuilt the package, your bb file still the same one, so you will get the same error, I send you my bb file, and I can build it successful, pls try again
6,103件の閲覧回数
afv2000
thanks for your help.
how do i get your bb file in this site?
it is my first time to ask issue in this forum.
thanks.
6,224件の閲覧回数
afv2000
i just using bitbake after clean up
bitbake -c clean optee-client
thanks.
6,219件の閲覧回数
joanxie
did you use original building command like
repo init -u https://source.codeaurora.org/external/imx/imx-manifest
-b imx-linux-zeus -m imx-5.4.3-2.0.0.xml
or use https://github.com/nxp-imx/imx-manifest to replace https://source.codeaurora.org/external/imx/imx-manifest ?
6,213件の閲覧回数
afv2000
i changed OPTEE_CLIENT_SRC in optee-client_3.2.0.imx.bb like below
SRCBRANCH = "imx_4.14.78_1.0.0_ga"
-OPTEE_CLIENT_SRC ?= "git://source.codeaurora.org/external/imx/imx-optee-client.git;protocol=https"
+OPTEE_CLIENT_SRC ?= "https://github.com/nxp-imx/imx-optee-client.git;protocol=https"
+SRC_URI[md5sum]= "965bc1e91a14762841ac47007b53d5d8"
SRCREV = "d06647d201520ac57f1331e97db6138d63bc2666"
i replace from codeaurora to github
6,167件の閲覧回数
joanxie
I don't think you need change this, how about use your previous bb file?
I tested it on my side, I didn't change the bb file, when I clean this and build it again successfully
SRCBRANCH = "lf-5.15.5_1.0.0"
SRC_URI = " \
git://source.codeaurora.org/external/imx/imx-optee-client.git;protocol=https;branch=${SRCBRANCH} \
file://tee-supplicant.service \
SRCREV = "182874320395787a389e5b0f7df02b32f3c0a1b0"
6,158件の閲覧回数
afv2000
dear NXP
git://source.codeaurora.org is offically close in this year.
so we can not use codeaurora,
and other article, they recommand below
6,163件の閲覧回数
afv2000
my previous bb file is below
1) optee-client_3.2.0.imx.bb
# Copyright (C) 2017-2018 NXP
SUMMARY = "OPTEE Client libs"
HOMEPAGE = "http://www.optee.org/"
LICENSE = "BSD"
LIC_FILES_CHKSUM = "file://LICENSE;md5=69663ab153298557a59c67a60a743e5b"
inherit pythonnative systemd
FILESEXTRAPATHS_prepend := "${THISDIR}/${PN}:"
SRC_URI_append = " file://0001-libteec-refactor-_dprintf.patch \
file://tee-supplicant.service"
S = "${WORKDIR}/git"
SYSTEMD_SERVICE_${PN} = "tee-supplicant.service"
EXTRA_OEMAKE = "CFG_SECURE_DATA_PATH=y"
2) optee-client_3.7.0.imx.bb
6,051件の閲覧回数
joanxie
if you just clean optee-client and bitback optee-client again with the previous bb file, what's result you get? I know nxp source code move to github, if you built the old bsp, you need change the address from codeaurora to github the repo init, but I had a old bsp version like yours(my bb file uses codeaurora ), I clean and build again without changing bb file(I shared with you) successfully, so I ask you trying this
5,900件の閲覧回数
afv2000
final answer.
from
to
6,228件の閲覧回数
joanxie
share your building steps, let me reproduce this on my side
6,205件の閲覧回数
afv2000
thanks.
