how can I build qtbase by using cross compiler instead of bitbake
1,475 次查看
wangtsungli
Hi Community,
I'm working on Yocto Project 2.0.
Recently, I build qtbase by below command.
bitbake qtbase
After this command was executed, it would generate source code and some other files under "build-wayland-q/tmp/work/cortexa9hf-vfp-neon-mx6qdl-poky-linux-gnueabi/".
Here is the condition occurred.
I tried to modify the source code and want to build it.
However I do not know how to build it.
bitbake command will catch original patch and build it but I need to build the new source code that I had modified.
How can I build it?
Could I use qmake or cross compiler?
Thanks in Advanced!
1,306 次查看
joanxie
you can build toolchian to build the source code, for more detailed information, pls refer to the document as below:
https://community.nxp.com/docs/DOC-95122
