gstreamer frame skip
y-iijima-emb
I am using IMX8MM-EVK with the MINISASTOCSI accessory and work it with Linux 5.10.35_2.0.0. When I input the command as below,  I am getting kernel message : "skip frame 1" once.
gst-launch-1.0 v4l2src device=/dev/video0 ! waylandsink
It means that drop frame occured? No kernel message shows when I capture image with v4l2-ctl.
Zhiming_Liu
@y-iijima-emb
"skip frame 1 " message does not mean frame drop.This is normal.
y-iijima-emb
Hi nxf65025,
I tried gst test according to the user guide : Section 7.3.8 Camera preview, kernel message : "skip frame 1" was showed as ever. Test command is as below.
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=(string)YUY2,width=640,height=480,framerate=(fraction)30/1 ! autovideosink
I'm trying to port the camera sensor(IMX226) that supports external trigger in the future. Before that, I would like to confirm that showing "skip frame" message does not mean frame drop.
Zhiming_Liu
@y-iijima-emb
Zhiming_Liu
Hi @y-iijima-emb
Can you follow the user guide to gst test?
https://www.nxp.com/docs/en/user-guide/IMX_LINUX_USERS_GUIDE.pdf
