gpu driver & page size
xinxinhuang
      my board has 3G ddr,in Linux config the default page size is 4k,so it cost over 500ms to create pages;in make menuconfig i change it to 16k, it seem Linux work well and cost 150ms in create pages,but the GPU driver have a error dump so the weston not work well;i want to know whether the GPU driver support 16k page size,if so,how to do ?
board:imx8qxp-mek
bsp:4.9.88-2.2.0_8qxp_beta2
      thanks!
joanxie
where did you change the page size in the menuconfig? could you tell me your detailed test steps? and what gpu error do you get?
xinxinhuang
      Hi,Joan Xie:
      I config the page size in kernel features/page size:
    There is not any test,  just normal boot, when the weston in launchering, the GPU driver throw an error dump, following is the log:
[BEGIN] 2018/12/19 星期三 下午 3:10:30
[2018/12/19 星期三 下午 3:10:33] imx8qxpmek login: ?
[2018/12/19 星期三 下午 3:10:33] U-Boot 2017.03-imx_v2017.03_4.9.88_imx8qxp_beta2+g84c4e82 (Nov 29 2018 - 12:27:49 +0800)
[2018/12/19 星期三 下午 3:10:33] CPU: Freescale i.MX8QXP revA A35 at 1200 MHz at 40C
[2018/12/19 星期三 下午 3:10:33] Model: Freescale i.MX8QXP MEK
[2018/12/19 星期三 下午 3:10:33] Board: iMX8QXP MEK
[2018/12/19 星期三 下午 3:10:33] Boot: MMC0
[2018/12/19 星期三 下午 3:10:33] DRAM: 3 GiB
[2018/12/19 星期三 下午 3:10:33] MMC: FSL_SDHC: 0
[2018/12/19 星期三 下午 3:10:33] Using default environment
[2018/12/19 星期三 下午 3:10:33] In: serial@5a060000
[2018/12/19 星期三 下午 3:10:33] Out: serial@5a060000
[2018/12/19 星期三 下午 3:10:33] Err: serial@5a060000
[2018/12/19 星期三 下午 3:10:33] Net: [board_eth_init] 290
[2018/12/19 星期三 下午 3:10:33] FEC0
[2018/12/19 星期三 下午 3:10:33] Booting from mmc ...
[2018/12/19 星期三 下午 3:10:33] ## Flattened Device Tree blob at 83000000
[2018/12/19 星期三 下午 3:10:33] Booting using the fdt blob at 0x83000000
[2018/12/19 星期三 下午 3:10:33] Using Device Tree in place at 0000000083000000, end 000000008300deb3
[2018/12/19 星期三 下午 3:10:33] Starting kernel ...
[2018/12/19 星期三 下午 3:10:33] Booting Linux on physical CPU 0x0
[2018/12/19 星期三 下午 3:10:33] Linux version 4.9.88-imx_4.9.88_imx8qxp_beta2+g05f46d3 (huangxinxin@huangxinxin) (gcc version 7.3.0 (GCC) ) #56 SMP PREEMPT Wed Dec 19 15:04:49 CST 2018
[2018/12/19 星期三 下午 3:10:33] Boot CPU: AArch64 Processor [410fd041]
[2018/12/19 星期三 下午 3:10:33] earlycon: lpuart32 at MMIO 0x000000005a060000 (options '115200,115200')
[2018/12/19 星期三 下午 3:10:33] bootconsole [lpuart32] enabled
[2018/12/19 星期三 下午 3:10:33] OF: reserved mem: failed to allocate memory for node 'linux,cma'
[2018/12/19 星期三 下午 3:10:33] cma: Reserved 384 MiB at 0x00000000e8000000
[2018/12/19 星期三 下午 3:10:34] psci: probing for conduit method from DT.
[2018/12/19 星期三 下午 3:10:34] psci: PSCIv1.0 detected in firmware.
[2018/12/19 星期三 下午 3:10:34] psci: Using standard PSCI v0.2 function IDs
[2018/12/19 星期三 下午 3:10:34] psci: MIGRATE_INFO_TYPE not supported.
[2018/12/19 星期三 下午 3:10:34] psci: SMC Calling Convention v1.0
[2018/12/19 星期三 下午 3:10:34] percpu: Embedded 6 pages/cpu @ffff80083ff30000 s47128 r8192 d42984 u98304
[2018/12/19 星期三 下午 3:10:34] Detected VIPT I-cache on CPU0
[2018/12/19 星期三 下午 3:10:34] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 185767
[2018/12/19 星期三 下午 3:10:34] Kernel command line: console=ttyLP0,115200 earlycon=lpuart32,0x5a060000,115200,115200 rdinit=/linuxrc root=/dev/mmcblk0p2 rootwait rw video=imxdpufb5:off video=imxdpufb6:off video=imxdpufb7:off
[2018/12/19 星期三 下午 3:10:34] log_buf_len individual max cpu contribution: 4096 bytes
[2018/12/19 星期三 下午 3:10:34] log_buf_len total cpu_extra contributions: 12288 bytes
[2018/12/19 星期三 下午 3:10:34] log_buf_len min size: 16384 bytes
[2018/12/19 星期三 下午 3:10:34] log_buf_len: 32768 bytes
[2018/12/19 星期三 下午 3:10:34] early log buf free: 14480(88%)
[2018/12/19 星期三 下午 3:10:34] PID hash table entries: 4096 (order: 1, 32768 bytes)
[2018/12/19 星期三 下午 3:10:34] Dentry cache hash table entries: 524288 (order: 8, 4194304 bytes)
[2018/12/19 星期三 下午 3:10:34] Inode-cache hash table entries: 262144 (order: 7, 2097152 bytes)
[2018/12/19 星期三 下午 3:10:34] software IO TLB [mem 0xe3ffc000-0xe7ffc000] (64MB) mapped at [ffff800063ffc000-ffff800067ffbfff]
[2018/12/19 星期三 下午 3:10:34] Memory: 2364928K/2983936K available (5950K kernel code, 384K rwdata, 2208K rodata, 384K init, 306K bss, 225792K reserved, 393216K cma-reserved)
[2018/12/19 星期三 下午 3:10:34] Virtual kernel memory layout:
[2018/12/19 星期三 下午 3:10:34] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[2018/12/19 星期三 下午 3:10:34] vmalloc : 0xffff000008000000 - 0xffff7f6fffff0000 (130495 GB)
[2018/12/19 星期三 下午 3:10:34] .text : 0xffff000008080000 - 0xffff000008650000 ( 5952 KB)
[2018/12/19 星期三 下午 3:10:34] .rodata : 0xffff000008650000 - 0xffff000008880000 ( 2240 KB)
[2018/12/19 星期三 下午 3:10:34] .init : 0xffff000008880000 - 0xffff0000088e0000 ( 384 KB)
[2018/12/19 星期三 下午 3:10:34] .data : 0xffff0000088e0000 - 0xffff000008940008 ( 385 KB)
[2018/12/19 星期三 下午 3:10:34] .bss : 0xffff000008940008 - 0xffff00000898c9ac ( 307 KB)
[2018/12/19 星期三 下午 3:10:34] fixed : 0xffff7f7ffe7f4000 - 0xffff7f7ffec00000 ( 4144 KB)
[2018/12/19 星期三 下午 3:10:34] PCI I/O : 0xffff7f7ffee00000 - 0xffff7f7fffe00000 ( 16 MB)
[2018/12/19 星期三 下午 3:10:34] vmemmap : 0xffff7f8000000000 - 0xffff800000000000 ( 512 GB maximum)
[2018/12/19 星期三 下午 3:10:34] 0xffff7f8000002000 - 0xffff7f8008400000 ( 131 MB actual)
[2018/12/19 星期三 下午 3:10:34] memory : 0xffff800000200000 - 0xffff800840000000 ( 33790 MB)
[2018/12/19 星期三 下午 3:10:34] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[2018/12/19 星期三 下午 3:10:34] Preemptible hierarchical RCU implementation.
[2018/12/19 星期三 下午 3:10:34] Build-time adjustment of leaf fanout to 64.
[2018/12/19 星期三 下午 3:10:34] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[2018/12/19 星期三 下午 3:10:34] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[2018/12/19 星期三 下午 3:10:34] NR_IRQS:64 nr_irqs:64 0
[2018/12/19 星期三 下午 3:10:34] GICv3: GIC: Using split EOI/Deactivate mode
[2018/12/19 星期三 下午 3:10:34] GICv3: CPU0: found redistributor 0 region 0:0x0000000051b00000
[2018/12/19 星期三 下午 3:10:34] arm_arch_timer: Architected cp15 timer(s) running at 8.00MHz (phys).
[2018/12/19 星期三 下午 3:10:34] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[2018/12/19 星期三 下午 3:10:34] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[2018/12/19 星期三 下午 3:10:34] Console: colour dummy device 80x25
[2018/12/19 星期三 下午 3:10:34] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[2018/12/19 星期三 下午 3:10:34] pid_max: default: 32768 minimum: 301
[2018/12/19 星期三 下午 3:10:34] Mount-cache hash table entries: 8192 (order: 2, 65536 bytes)
[2018/12/19 星期三 下午 3:10:34] Mountpoint-cache hash table entries: 8192 (order: 2, 65536 bytes)
[2018/12/19 星期三 下午 3:10:34] ASID allocator initialised with 65536 entries
[2018/12/19 星期三 下午 3:10:34] *****Initialized MU
[2018/12/19 星期三 下午 3:10:34] ***** imx8_init_pm_domains *****
[2018/12/19 星期三 下午 3:10:34] CPU identified as i.MX8QXP, silicon rev 1.0
[2018/12/19 星期三 下午 3:10:34] Detected VIPT I-cache on CPU1
[2018/12/19 星期三 下午 3:10:34] GICv3: CPU1: found redistributor 1 region 0:0x0000000051b20000
[2018/12/19 星期三 下午 3:10:34] CPU1: Booted secondary processor [410fd041]
[2018/12/19 星期三 下午 3:10:34] Detected VIPT I-cache on CPU2
[2018/12/19 星期三 下午 3:10:34] GICv3: CPU2: found redistributor 2 region 0:0x0000000051b40000
[2018/12/19 星期三 下午 3:10:34] CPU2: Booted secondary processor [410fd041]
[2018/12/19 星期三 下午 3:10:34] Detected VIPT I-cache on CPU3
[2018/12/19 星期三 下午 3:10:34] GICv3: CPU3: found redistributor 3 region 0:0x0000000051b60000
[2018/12/19 星期三 下午 3:10:34] CPU3: Booted secondary processor [410fd041]
[2018/12/19 星期三 下午 3:10:34] Brought up 4 CPUs
[2018/12/19 星期三 下午 3:10:34] SMP: Total of 4 processors activated.
[2018/12/19 星期三 下午 3:10:34] CPU features: detected feature: GIC system register CPU interface
[2018/12/19 星期三 下午 3:10:34] CPU features: detected feature: 32-bit EL0 Support
[2018/12/19 星期三 下午 3:10:34] CPU: All CPU(s) started at EL2
[2018/12/19 星期三 下午 3:10:34] devtmpfs: initialized
[2018/12/19 星期三 下午 3:10:34] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[2018/12/19 星期三 下午 3:10:34] futex hash table entries: 1024 (order: 3, 131072 bytes)
[2018/12/19 星期三 下午 3:10:34] pinctrl core: initialized pinctrl subsystem
[2018/12/19 星期三 下午 3:10:34] NET: Registered protocol family 16
[2018/12/19 星期三 下午 3:10:34] vdso: 2 pages (1 code @ ffff00000865c000, 1 data @ ffff0000088e4000)
[2018/12/19 星期三 下午 3:10:34] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[2018/12/19 星期三 下午 3:10:34] DMA: preallocated 256 KiB pool for atomic allocations
[2018/12/19 星期三 下午 3:10:34] MU and Power domains initialized
[2018/12/19 星期三 下午 3:10:34] ***** imx8qxp_clocks_init *****
[2018/12/19 星期三 下午 3:10:34] i.MX8QXP clk 168: register failed with -19
[2018/12/19 星期三 下午 3:10:34] i.MX8QXP clk 169: register failed with -19
[2018/12/19 星期三 下午 3:10:34] imx8qxp-pinctrl iomuxc: initialized IMX pinctrl driver
[2018/12/19 星期三 下午 3:10:34] 5b100000.usbphy supply phy-3p0 not found, using dummy regulator
[2018/12/19 星期三 下午 3:10:34] SCSI subsystem initialized
[2018/12/19 星期三 下午 3:10:34] usbcore: registered new interface driver usbfs
[2018/12/19 星期三 下午 3:10:34] usbcore: registered new interface driver hub
[2018/12/19 星期三 下午 3:10:34] usbcore: registered new device driver usb
[2018/12/19 星期三 下午 3:10:34] i2c i2c-0: LPI2C adapter registered
[2018/12/19 星期三 下午 3:10:34] i2c i2c-1: LPI2C adapter registered
[2018/12/19 星期三 下午 3:10:34] media: Linux media interface: v0.10
[2018/12/19 星期三 下午 3:10:34] Linux video capture interface: v2.00
[2018/12/19 星期三 下午 3:10:34] pps_core: LinuxPPS API ver. 1 registered
[2018/12/19 星期三 下午 3:10:34] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[2018/12/19 星期三 下午 3:10:34] PTP clock support registered
[2018/12/19 星期三 下午 3:10:34] MU is ready for cross core communication!
[2018/12/19 星期三 下午 3:10:34] virtio_rpmsg_bus virtio0: rpmsg host is online
[2018/12/19 星期三 下午 3:10:34] imx rpmsg driver is registered.
[2018/12/19 星期三 下午 3:10:34] clocksource: Switched to clocksource arch_sys_counter
[2018/12/19 星期三 下午 3:10:34] NET: Registered protocol family 2
[2018/12/19 星期三 下午 3:10:34] TCP established hash table entries: 32768 (order: 4, 262144 bytes)
[2018/12/19 星期三 下午 3:10:34] TCP bind hash table entries: 32768 (order: 5, 524288 bytes)
[2018/12/19 星期三 下午 3:10:34] TCP: Hash tables configured (established 32768 bind 32768)
[2018/12/19 星期三 下午 3:10:34] UDP hash table entries: 2048 (order: 2, 65536 bytes)
[2018/12/19 星期三 下午 3:10:34] UDP-Lite hash table entries: 2048 (order: 2, 65536 bytes)
[2018/12/19 星期三 下午 3:10:34] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[2018/12/19 星期三 下午 3:10:34] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[2018/12/19 星期三 下午 3:10:34] io scheduler noop registered
[2018/12/19 星期三 下午 3:10:34] io scheduler cfq registered (default)
[2018/12/19 星期三 下午 3:10:34] 5a060000.serial: ttyLP0 at MMIO 0x5a060000 (irq = 47, base_baud = 5000000) is a FSL_LPUARconsole [ttyLP0] enabled
[2018/12/19 星期三 下午 3:10:34] console [ttyLP0] enabled
[2018/12/19 星期三 下午 3:10:34] bootconsole [lpuart32] disabled
[2018/12/19 星期三 下午 3:10:34] fsl-lpuart 5a060000.serial: NO DMA tx channel, run at cpu mode
[2018/12/19 星期三 下午 3:10:34] fsl-lpuart 5a060000.serial: NO DMA rx channel, run at cpu mode
[2018/12/19 星期三 下午 3:10:34] 5a080000.serial: ttyLP2 at MMIO 0x5a080000 (irq = 48, base_baud = 5000000) is a FSL_LPUART
[2018/12/19 星期三 下午 3:10:35] imx8-dpr-channel 560d0000.dpr-channel: Linked as a consumer to 56040000.prg
[2018/12/19 星期三 下午 3:10:35] imx8-dpr-channel 560e0000.dpr-channel: Linked as a consumer to 56050000.prg
[2018/12/19 星期三 下午 3:10:35] imx8-dpr-channel 560e0000.dpr-channel: Linked as a consumer to 56040000.prg
[2018/12/19 星期三 下午 3:10:35] imx8-dpr-channel 560f0000.dpr-channel: Linked as a consumer to 56060000.prg
[2018/12/19 星期三 下午 3:10:35] imx8-dpr-channel 56100000.dpr-channel: Linked as a consumer to 56070000.prg
[2018/12/19 星期三 下午 3:10:35] imx8-dpr-channel 56100000.dpr-channel: Linked as a consumer to 56080000.prg
[2018/12/19 星期三 下午 3:10:35] imx8-dpr-channel 56110000.dpr-channel: Linked as a consumer to 56090000.prg
[2018/12/19 星期三 下午 3:10:35] imx8-dpr-channel 56110000.dpr-channel: Linked as a consumer to 560a0000.prg
[2018/12/19 星期三 下午 3:10:35] imx8-dpr-channel 56120000.dpr-channel: Linked as a consumer to 560b0000.prg
[2018/12/19 星期三 下午 3:10:35] imx8-dpr-channel 56120000.dpr-channel: Linked as a consumer to 560c0000.prg
[2018/12/19 星期三 下午 3:10:35] dpu-core 56180000.dpu: Linked as a consumer to 56100000.dpr-channel
[2018/12/19 星期三 下午 3:10:35] dpu-core 56180000.dpu: Linked as a consumer to 56110000.dpr-channel
[2018/12/19 星期三 下午 3:10:35] dpu-core 56180000.dpu: Linked as a consumer to 560f0000.dpr-channel
[2018/12/19 星期三 下午 3:10:35] dpu-core 56180000.dpu: Linked as a consumer to 56120000.dpr-channel
[2018/12/19 星期三 下午 3:10:35] dpu-core 56180000.dpu: driver probed
[2018/12/19 星期三 下午 3:10:35] [drm] Initialized
[2018/12/19 星期三 下午 3:10:35] ds90ub947 1-000c: ds947 is not there
[2018/12/19 星期三 下午 3:10:35] ds90ub947 1-000c: ds947/ds948 inited
[2018/12/19 星期三 下午 3:10:35] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[2018/12/19 星期三 下午 3:10:35] [drm] No driver support for vblank timestamp query.
[2018/12/19 星期三 下午 3:10:35] dpu-core 56180000.dpu: Linked as a consumer to 560d0000.dpr-channel
[2018/12/19 星期三 下午 3:10:35] dpu-core 56180000.dpu: Linked as a consumer to 560e0000.dpr-channel
[2018/12/19 星期三 下午 3:10:35] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[2018/12/19 星期三 下午 3:10:35] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[2018/12/19 星期三 下午 3:10:35] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[2018/12/19 星期三 下午 3:10:35] imx-ldb ldb@562210e0: dual-channel mode
[2018/12/19 星期三 下午 3:10:35] imx-drm display-subsystem: bound ldb@562210e0 (ops imx_ldb_ops)
[2018/12/19 星期三 下午 3:10:35] imx-drm display-subsystem: fb0: frame buffer device
[2018/12/19 星期三 下午 3:10:35] libphy: Fixed MDIO Bus: probed
[2018/12/19 星期三 下午 3:10:35] 5b040000.ethernet supply phy not found, using dummy regulator
[2018/12/19 星期三 下午 3:10:35] pps pps0: new PPS source ptp0
[2018/12/19 星期三 下午 3:10:35] libphy: fec_enet_mii_bus: probed
[2018/12/19 星期三 下午 3:10:35] fec 5b040000.ethernet eth0: registered PHC device 0
[2018/12/19 星期三 下午 3:10:35] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[2018/12/19 星期三 下午 3:10:35] ehci-platform: EHCI generic platform driver
[2018/12/19 星期三 下午 3:10:35] usbcore: registered new interface driver usb-storage
[2018/12/19 星期三 下午 3:10:35] 5b0d0200.usbmisc supply vbus-wakeup not found, using dummy regulator
[2018/12/19 星期三 下午 3:10:35] ci_hdrc ci_hdrc.0: EHCI Host Controller
[2018/12/19 星期三 下午 3:10:35] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[2018/12/19 星期三 下午 3:10:35] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[2018/12/19 星期三 下午 3:10:35] hub 1-0:1.0: USB hub found
[2018/12/19 星期三 下午 3:10:35] hub 1-0:1.0: 1 port detected
[2018/12/19 星期三 下午 3:10:35] input: sc-powerkey as /devices/platform/sc-powerkey/input/input0
[2018/12/19 星期三 下午 3:10:35] imx_sc_rtc rtc: rtc core: registered rtc as rtc0
[2018/12/19 星期三 下午 3:10:35] i2c /dev entries driver
[2018/12/19 星期三 下午 3:10:35] mxc-mipi-csi2 58227000.csi: mipi_csi2_probe
[2018/12/19 星期三 下午 3:10:35] mxc-mipi-csi2 58227000.csi: lanes: 4, name: mxc-mipi-csi2.0
[2018/12/19 星期三 下午 3:10:35] mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
[2018/12/19 星期三 下午 3:10:35] sdhci: Secure Digital Host Controller Interface driver
[2018/12/19 星期三 下午 3:10:35] sdhci: Copyright(c) Pierre Ossman
[2018/12/19 星期三 下午 3:10:35] sdhci-pltfm: SDHCI platform and OF driver helper
[2018/12/19 星期三 下午 3:10:35] mmc0: CQHCI version 5.10
[2018/12/19 星期三 下午 3:10:35] mmc0: SDHCI controller on 5b010000.usdhc [5b010000.usdhc] using ADMA
[2018/12/19 星期三 下午 3:10:35] NET: Registered protocol family 26
[2018/12/19 星期三 下午 3:10:35] NET: Registered protocol family 10
[2018/12/19 星期三 下午 3:10:35] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[2018/12/19 星期三 下午 3:10:35] NET: Registered protocol family 17
[2018/12/19 星期三 下午 3:10:35] 8021q: 802.1Q VLAN Support v1.8
[2018/12/19 星期三 下午 3:10:35] Key type dns_resolver registered
[2018/12/19 星期三 下午 3:10:35] registered taskstats version 1
[2018/12/19 星期三 下午 3:10:35] imx8_cpufreq_init: cluster 0 running at freq 1200 MHz, suspend freq 1200 MHz
[2018/12/19 星期三 下午 3:10:35] imx_sc_rtc rtc: setting system clock to 1970-01-01 00:00:01 UTC (1)
[2018/12/19 星期三 下午 3:10:35] Waiting for root device /dev/mmcblk0p2...
[2018/12/19 星期三 下午 3:10:35] mmc0: new HS400 MMC card at address 0001
[2018/12/19 星期三 下午 3:10:35] mmcblk0: mmc0:0001 R1J57L 29.1 GiB
[2018/12/19 星期三 下午 3:10:35] mmcblk0boot0: mmc0:0001 R1J57L partition 1 8.00 MiB
[2018/12/19 星期三 下午 3:10:35] mmcblk0boot1: mmc0:0001 R1J57L partition 2 8.00 MiB
[2018/12/19 星期三 下午 3:10:35] mmcblk0rpmb: mmc0:0001 R1J57L partition 3 4.00 MiB
[2018/12/19 星期三 下午 3:10:35] mmcblk0: p1 p2 p3 p4
[2018/12/19 星期三 下午 3:10:35] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[2018/12/19 星期三 下午 3:10:35] EXT4-fs (mmcblk0p2): recovery complete
[2018/12/19 星期三 下午 3:10:35] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[2018/12/19 星期三 下午 3:10:35] VFS: Mounted root (ext3 filesystem) on device 179:2.
[2018/12/19 星期三 下午 3:10:35] devtmpfs: mounted
[2018/12/19 星期三 下午 3:10:35] Freeing unused kernel memory: 384K
[2018/12/19 星期三 下午 3:10:35] INIT: version 2.88 booting
[2018/12/19 星期三 下午 3:10:35] random: fast init done
[2018/12/19 星期三 下午 3:10:35] Galcore version 6.2.4.150331
[2018/12/19 星期三 下午 3:10:35] Starting udev
[2018/12/19 星期三 下午 3:10:35] udevd[835]: starting version 3.2.2
[2018/12/19 星期三 下午 3:10:35] udevd[836]: starting eudev-3.2.2
[2018/12/19 星期三 下午 3:10:35] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[2018/12/19 星期三 下午 3:10:35] Starting QT Demo ...
[2018/12/19 星期三 下午 3:10:35] QT Demo Started ...
[2018/12/19 星期三 下午 3:10:36] Wed Dec 12 03:52:33 UTC 2018
[2018/12/19 星期三 下午 3:10:36] EXT4-fs (mmcblk0p4): mounting ext3 file system using the ext4 subsystem
[2018/12/19 星期三 下午 3:10:36] EXT4-fs (mmcblk0p4): recovery complete
[2018/12/19 星期三 下午 3:10:36] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[2018/12/19 星期三 下午 3:10:36] FAT-fs (mmcblk0p3): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[2018/12/19 星期三 下午 3:10:36] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[2018/12/19 星期三 下午 3:10:36] ALSA: Restoring mixer settings...
[2018/12/19 星期三 下午 3:10:36] INIT: Entering runlevel: 5
[2018/12/19 星期三 下午 3:10:36] /usr/sbin/alsactl: load_state:1735: No soundcards found...
[2018/12/19 星期三 下午 3:10:36] Configuring network interfaces... Atheros 8031 ethernet 5b040000.ethernet-1:04: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=5b040000.ethernet-1:04, irq=-1)
[2018/12/19 星期三 下午 3:10:36] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[2018/12/19 星期三 下午 3:10:36] done.
[2018/12/19 星期三 下午 3:10:36] Starting system message bus: dbus.
[2018/12/19 星期三 下午 3:10:36] Starting Connection Manager
[2018/12/19 星期三 下午 3:10:36] Starting Dropbear SSH server: dropbear.
[2018/12/19 星期三 下午 3:10:36] Starting rpcbind daemon...done.
[2018/12/19 星期三 下午 3:10:36] starting statd: done
[2018/12/19 星期三 下午 3:10:36] Starting atd: OK
[2018/12/19 星期三 下午 3:10:36] exportfs: can't open /etc/exports for reading
[2018/12/19 星期三 下午 3:10:36] NFS daemon support not enabled in kernel
[2018/12/19 星期三 下午 3:10:36] Starting system log daemon...0
[2018/12/19 星期三 下午 3:10:37] Starting kernel log daemon...0
[2018/12/19 星期三 下午 3:10:37] * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
[2018/12/19 星期三 下午 3:10:37] * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon [ ok ]
[2018/12/19 星期三 下午 3:10:37] Starting Telephony daemon
[2018/12/19 星期三 下午 3:10:37] Starting Linux NFC daemon
[2018/12/19 星期三 下午 3:10:37] Starting crond: OK
[2018/12/19 星期三 下午 3:10:37] Running local boot scripts (/etc/rc.local).
[2018/12/19 星期三 下午 3:10:37] NXP i.MX Release Distro 4.9.88-2.2.0_8qxp_beta2 imx8qxpmek /dev/ttyLP0
[2018/12/19 星期三 下午 3:11:06] imx8qxpmek login: **************************
[2018/12/19 星期三 下午 3:11:06] *** GPU DRV CONFIG ***
[2018/12/19 星期三 下午 3:11:06] **************************
[2018/12/19 星期三 下午 3:11:06] Galcore version 6.2.4.150331
[2018/12/19 星期三 下午 3:11:06] Galcore options:
[2018/12/19 星期三 下午 3:11:06] contiguousSize = 0x08000000
[2018/12/19 星期三 下午 3:11:06] contiguousBase = 0x00000000
[2018/12/19 星期三 下午 3:11:06] externalSize = 0x00000000
[2018/12/19 星期三 下午 3:11:06] externalBase = 0x00000000
[2018/12/19 星期三 下午 3:11:06] bankSize = 0x00000000
[2018/12/19 星期三 下午 3:11:06] fastClear = -1
[2018/12/19 星期三 下午 3:11:06] compression = 13
[2018/12/19 星期三 下午 3:11:06] signal = 48
[2018/12/19 星期三 下午 3:11:06] powerManagement = 1
[2018/12/19 星期三 下午 3:11:06] baseAddress = 0x80000000
[2018/12/19 星期三 下午 3:11:06] physSize = 0x80000000
[2018/12/19 星期三 下午 3:11:06] logFileSize = 0 KB
[2018/12/19 星期三 下午 3:11:06] recovery = 0
[2018/12/19 星期三 下午 3:11:06] stuckDump = 0
[2018/12/19 星期三 下午 3:11:06] gpuProfiler = 0
[2018/12/19 星期三 下午 3:11:06] irqs = 45,
[2018/12/19 星期三 下午 3:11:06] -1, -1,
[2018/12/19 星期三 下午 3:11:06] registerBases = 0x53100000,
[2018/12/19 星期三 下午 3:11:06] 0x00000000, 0x00000000,
[2018/12/19 星期三 下午 3:11:06] registerSizes = 0x00040000,
[2018/12/19 星期三 下午 3:11:06] 0x00000800, 0x00000800,
[2018/12/19 星期三 下午 3:11:06] chipIDs = 0xFFFFFFFF,
[2018/12/19 星期三 下午 3:11:06] 0xFFFFFFFF, 0xFFFFFFFF,
[2018/12/19 星期三 下午 3:11:06] Build options:
[2018/12/19 星期三 下午 3:11:06] gcdGPU_TIMEOUT = 20000
[2018/12/19 星期三 下午 3:11:06] gcdGPU_2D_TIMEOUT = 20000
[2018/12/19 星期三 下午 3:11:06] gcdINTERRUPT_STATISTIC = 1
[2018/12/19 星期三 下午 3:11:06] GPU[0](ChipModel=0x3000 ChipRevision=0x5514):
[2018/12/19 星期三 下午 3:11:06] *** GPU STATE DUMP ***
[2018/12/19 星期三 下午 3:11:06] axi = 0x000000F8
[2018/12/19 星期三 下午 3:11:06] idle = 0x7FFFFFFE
[2018/12/19 星期三 下午 3:11:06] FE not idle
[2018/12/19 星期三 下午 3:11:06] DMA appears to be stuck at this address:
[2018/12/19 星期三 下午 3:11:06] 0x7FFFF010
[2018/12/19 星期三 下午 3:11:06] dmaLow = 0x10000000
[2018/12/19 星期三 下午 3:11:06] dmaHigh = 0x00000001
[2018/12/19 星期三 下午 3:11:06] dmaState = 0x00000000
[2018/12/19 星期三 下午 3:11:06] command state = 0 (PAR_IDLE_ST)
[2018/12/19 星期三 下午 3:11:06] command DMA state = 0 (CMD_IDLE_ST)
[2018/12/19 星期三 下午 3:11:06] command fetch state = 0 (FET_IDLE_ST)
[2018/12/19 星期三 下午 3:11:06] DMA request state = 0 (REQ_IDLE_ST)
[2018/12/19 星期三 下午 3:11:06] cal state = 0 (CAL_IDLE_ST)
[2018/12/19 星期三 下午 3:11:06] VE request state = 0 (VER_IDLE_ST)
[2018/12/19 星期三 下午 3:11:06] Debug registers:
[2018/12/19 星期三 下午 3:11:06] RA[0] debug registers:
[2018/12/19 星期三 下午 3:11:06] [00] 00000000 00000000 00000000 00000000 039F0000 00001A00 81928000 68100000
[2018/12/19 星期三 下午 3:11:06] [08] 00000000 00000000 00000000 00000000 00000000 00000018 055AC43C 00000000
[2018/12/19 星期三 下午 3:11:06] [10] 00000018 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [18] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [20] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [28] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [30] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [38] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [40] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [48] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [50] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [58] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [60] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [68] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [70] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [78] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [80] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [88] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [90] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [98] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [A0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [A8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [B0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [B8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [C0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [C8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [D0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [D8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [E0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [E8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [F0] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] [F8] 12344321 12344321 12344321 12344321 12344321 12344321 12344321 12344321
[2018/12/19 星期三 下午 3:11:06] TX[0] debug registers:
[2018/12/19 星期三 下午 3:11:06] [00] 00000000 00000000 00000000 00000000 00001FE7 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:06] [08] 00000000 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [10] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [18] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [20] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [28] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [30] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [38] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [40] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [48] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [50] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [58] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [60] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [68] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [70] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] [78] 12211221 12211221 12211221 12211221 12211221 12211221 12211221 12211221
[2018/12/19 星期三 下午 3:11:06] FE[0] debug registers:
[2018/12/19 星期三 下午 3:11:06] [00] 7FFFF010 10000000 00000001 0000025A 00060002 00000000 00004AB9 00003F4D
[2018/12/19 星期三 下午 3:11:06] [08] 0000000E 00000000 00000000 00000000 00000000 9D024800 00000030 BABEF00D
[2018/12/19 星期三 下午 3:11:06] [10] 00000000 00000000 142FD595 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [18] 45674567 45674567 10000000 45674567 10000000 45674567 00000000 00000000
[2018/12/19 星期三 下午 3:11:06] [20] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [28] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [30] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [38] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [40] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [48] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [50] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [58] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [60] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [68] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [70] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [78] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [80] 7FFFF010 10000000 00000001 0000025A 00060002 00000000 00004AB9 00003F4D
[2018/12/19 星期三 下午 3:11:06] [88] 0000000E 00000000 00000000 00000000 00000000 8FFFFE00 00000031 BABEF00D
[2018/12/19 星期三 下午 3:11:06] [90] 00000000 00000000 18F6AF1B 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [98] 45674567 45674567 00000000 45674567 00000000 45674567 00000000 00000000
[2018/12/19 星期三 下午 3:11:06] [A0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [A8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [B0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [B8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:06] [C0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:07] [C8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:07] [D0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:07] [D8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:07] [E0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:07] [E8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:07] [F0] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:07] [F8] 45674567 45674567 45674567 45674567 45674567 45674567 45674567 45674567
[2018/12/19 星期三 下午 3:11:07] PE[0] debug registers:
[2018/12/19 星期三 下午 3:11:07] [00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [08] D0004B00 20004B00 9D82308C 11111100 22222200 33333300 44444400 00000000
[2018/12/19 星期三 下午 3:11:07] [10] 00000000 00000000 00000000 00000000 00000000 DEADBF00 BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [18] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [28] 00000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [30] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [38] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [40] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [48] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [50] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [58] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [60] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [68] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [70] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [78] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [80] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [88] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [90] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [98] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [A0] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [A8] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [B0] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [B8] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [C0] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [C8] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [D0] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [D8] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [E0] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [E8] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [F0] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] [F8] BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D BABEF00D
[2018/12/19 星期三 下午 3:11:07] PE[1] debug registers:
[2018/12/19 星期三 下午 3:11:07] DE[0] debug registers:
[2018/12/19 星期三 下午 3:11:07] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] SH[0] debug registers:
[2018/12/19 星期三 下午 3:11:07] [00] B2FFE82B 555FC000 00080005 00000A22 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:07] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 59563AB4
[2018/12/19 星期三 下午 3:11:07] [10] 00000000 59B2FDEB 00000000 0000000D 00000005 0000000D 00000007 00000014
[2018/12/19 星期三 下午 3:11:07] [18] 5A0FC18F 00000000 00000014 BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [20] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [28] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [30] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [38] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [40] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [48] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [50] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [58] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [60] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [68] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [70] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [78] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [80] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [88] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [90] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [98] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [A0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [A8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [B0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [B8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [C0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [C8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [D0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [D8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [E0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [E8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [F0] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D
[2018/12/19 星期三 下午 3:11:07] [F8] BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D BAB4F00D DEADBEEF
[2018/12/19 星期三 下午 3:11:07] PA[0] debug registers:
[2018/12/19 星期三 下午 3:11:08] [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] SE[0] debug registers:
[2018/12/19 星期三 下午 3:11:08] [00] 0A8550A8 01555555 15555555 05555540 05555555 00002501 00C00940 00000000
[2018/12/19 星期三 下午 3:11:08] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [10] 00000000 00000000 00000000 00000000 00000000 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [18] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [20] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [28] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [30] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [38] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [40] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [48] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [50] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [58] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [60] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [68] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [70] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [78] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [80] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [88] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [90] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [98] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [A0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [A8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [B0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [B8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [C0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [C8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [D0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [D8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [E0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [E8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [F0] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] [F8] 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E 5E5E5E5E
[2018/12/19 星期三 下午 3:11:08] MC[0] debug registers:
[2018/12/19 星期三 下午 3:11:08] [00] 00000000 00000000 00000000 00000000 00000000 00000000 FE0500B0 00000000
[2018/12/19 星期三 下午 3:11:08] [08] 00000000 00000000 00000000 00000000 0000000A 00000000 00000004 00000000
[2018/12/19 星期三 下午 3:11:08] [10] 00000000 00000000 00000000 00000000 00000002 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [18] 00000000 00002022 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [20] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [28] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [30] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [38] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [40] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [48] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [50] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [58] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [60] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [68] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [70] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [78] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [80] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [88] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [90] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [98] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [A0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [A8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [B0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [B8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [C0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [C8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [D0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [D8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [E0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [E8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [F0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] [F8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:08] MC[1] debug registers:
[2018/12/19 星期三 下午 3:11:08] [00] FE0500B0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:08] [18] 00000000 00000000 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [40] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [48] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [50] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [58] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [60] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [68] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [70] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [78] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [80] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [88] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [90] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [98] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [A0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [A8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [B0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [B8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [C0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [C8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [D0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [D8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [E0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [E8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [F0] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] [F8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[2018/12/19 星期三 下午 3:11:09] HI[0] debug registers:
[2018/12/19 星期三 下午 3:11:09] [00] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [08] 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [10] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [18] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [20] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [28] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [30] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [38] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [40] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [48] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [50] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [58] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [60] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [68] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [70] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [78] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [80] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [88] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [90] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [98] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [A0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [A8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [B0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [B8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [C0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [C8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [D0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [D8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [E0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [E8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [F0] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] [F8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[2018/12/19 星期三 下午 3:11:09] TPG[1] debug registers:
[2018/12/19 星期三 下午 3:11:09] [80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] TFB[1] debug registers:
[2018/12/19 星期三 下午 3:11:09] [A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] USC[1] debug registers:
[2018/12/19 星期三 下午 3:11:09] [C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] L2[0] debug registers:
[2018/12/19 星期三 下午 3:11:09] [00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] [78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:09] BLT[0] debug registers:
[2018/12/19 星期三 下午 3:11:09] Other Registers[0]:
[2018/12/19 星期三 下午 3:11:09] [0x0040] 0x0000000B
[2018/12/19 星期三 下午 3:11:09] [0x0044] 0x00000000
[2018/12/19 星期三 下午 3:11:09] [0x004C] 0x00000000
[2018/12/19 星期三 下午 3:11:09] [0x0050] 0x00000000
[2018/12/19 星期三 下午 3:11:09] [0x0054] 0x00000000
[2018/12/19 星期三 下午 3:11:09] [0x0058] 0x0000000B
[2018/12/19 星期三 下午 3:11:09] [0x005C] 0x00000004
[2018/12/19 星期三 下午 3:11:09] [0x0060] 0x00000004
[2018/12/19 星期三 下午 3:11:09] [0x043C] 0x00030000
[2018/12/19 星期三 下午 3:11:09] [0x0440] 0x00000000
[2018/12/19 星期三 下午 3:11:09] [0x0444] 0x00000000
[2018/12/19 星期三 下午 3:11:09] [0x0414] 0x3C000000
[2018/12/19 星期三 下午 3:11:09] [0x0100] 0x00140021
[2018/12/19 星期三 下午 3:11:09] MMU status from MC[0]:
[2018/12/19 星期三 下午 3:11:09] GPU[0](ChipModel=0x3000 ChipRevision=0x5514):
[2018/12/19 星期三 下午 3:11:09] **************************
[2018/12/19 星期三 下午 3:11:09] *** MMU ERROR DUMP ***
[2018/12/19 星期三 下午 3:11:09] MMU status = 0x00000002
[2018/12/19 星期三 下午 3:11:09] MMU0: page not present
[2018/12/19 星期三 下午 3:11:09] MMU0: exception address = 0x7FFFF000
[2018/12/19 星期三 下午 3:11:10] MTLB entry = 511
[2018/12/19 星期三 下午 3:11:10] STLB entry = 1023
[2018/12/19 星期三 下午 3:11:10] Offset = 0x00000000 (0)
[2018/12/19 星期三 下午 3:11:10] Page table entry = 0x00000002
[2018/12/19 星期三 下午 3:11:10] Other Registers[1]:
[2018/12/19 星期三 下午 3:11:10] [0x0040] 0x00000000
[2018/12/19 星期三 下午 3:11:10] [0x0044] 0x00000000
[2018/12/19 星期三 下午 3:11:10] [0x004C] 0x00000000
[2018/12/19 星期三 下午 3:11:10] [0x0050] 0x00000000
[2018/12/19 星期三 下午 3:11:10] [0x0054] 0x00000000
[2018/12/19 星期三 下午 3:11:10] [0x0058] 0x00000000
[2018/12/19 星期三 下午 3:11:10] [0x005C] 0x00000000
[2018/12/19 星期三 下午 3:11:10] [0x0060] 0x00000000
[2018/12/19 星期三 下午 3:11:10] [0x043C] 0x00000000
[2018/12/19 星期三 下午 3:11:10] [0x0440] 0x00000000
[2018/12/19 星期三 下午 3:11:10] [0x0444] 0x00000000
[2018/12/19 星期三 下午 3:11:10] [0x0414] 0x3C000000
[2018/12/19 星期三 下午 3:11:10] [0x0100] 0x00140021
[2018/12/19 星期三 下午 3:11:10] MMU status from MC[1]:
[2018/12/19 星期三 下午 3:11:10] GPU[0](ChipModel=0x3000 ChipRevision=0x5514):
[2018/12/19 星期三 下午 3:11:10] **************************
[2018/12/19 星期三 下午 3:11:10] *** MMU ERROR DUMP ***
[2018/12/19 星期三 下午 3:11:10] MMU status = 0x00000000
[2018/12/19 星期三 下午 3:11:10] Link stack:
[2018/12/19 星期三 下午 3:11:10] [0x00] 0x51A0AAF8 [0x01] 0xC0A13DB5 [0x02] 0xF8097D25 [0x03] 0xC177E4FA
[2018/12/19 星期三 下午 3:11:10] [0x04] 0x00100ED7 [0x05] 0x75727DBF [0x06] 0xF9B661A1 [0x07] 0xDB8CD25E
[2018/12/19 星期三 下午 3:11:10] [0x08] 0x1C64DC7D [0x09] 0x9404B9AA [0x0A] 0x0757FE31 [0x0B] 0x5A14B92F
[2018/12/19 星期三 下午 3:11:10] [0x0C] 0x9D024800 [0x0D] 0x8FFFFE00 [0x0E] 0x8FFFFE02 [0x0F] 0xD06A76F1
[2018/12/19 星期三 下午 3:11:10] PRE_STACK:
[2018/12/19 星期三 下午 3:11:10] 10F7FB98 344D0E0A 70489A7E 18678028 F4BD920E D22130C6 F3FF0598 BE1C5F30
[2018/12/19 星期三 下午 3:11:10] 43A26C10 3F4F9BD6 4736DD5E BDD6FA23 671C137A 157EAEE0 075FF7C6 F97AA7EF
[2018/12/19 星期三 下午 3:11:10] 0F3BA0E7 B1FA838B C54071D9 0EAF1036 E78179E8 1B3C1671 32C751E4 C3FD560D
[2018/12/19 星期三 下午 3:11:10] F71C447C 86157A23 A41D58D3 12CCFB69 84BB1872 3CD89168 979E0B58 2D5CF490
[2018/12/19 星期三 下午 3:11:10] DDBEF337 8904F885 953EF235 8736DD71 B596D75F 83F65D8F F2D6EF1C E5ED52C1
[2018/12/19 星期三 下午 3:11:10] 62B4E0F8 14A412E1 6293F9ED 4EB933CD 61A3FF63 262BB565 0167FECF 4610904C
[2018/12/19 星期三 下午 3:11:10] C524D34D 21A20A0C 30102272 29600C11 08010061 E80FC000 08010060 E8120000
[2018/12/19 星期三 下午 3:11:10] 08010068 00000000 08010E02 00000701 48000000 00000701 10000000 00000001
[2018/12/19 星期三 下午 3:11:10] CMD_STACK:
[2018/12/19 星期三 下午 3:11:10] 724BA18C 3863AD46 37C0A384 B033F840 57D444CE F070E0DF 3CA456C7 34DCB0A7
[2018/12/19 星期三 下午 3:11:10] FC6497C7 18698580 2CF48589 18610549 4CC075FD C9A17346 1C023F95 CD914206
[2018/12/19 星期三 下午 3:11:10] 1435B2F1 879F4F62 5C35D675 074B0800 5941EB38 4006C9D0 5D055399 104E5CF3
[2018/12/19 星期三 下午 3:11:10] 6804E311 BC5C0EBA 4004D462 1E11CE16 025C40C2 6C895155 35478A4B C8CE0684
[2018/12/19 星期三 下午 3:11:10] 606725A9 A56FC3BA 8B5E97AF DCFFCD3A E34E102B F06D4D1A A5970895 F96A0859
[2018/12/19 星期三 下午 3:11:10] 471C0BF1 ED8A9078 46048B9E E44A8530 7C1DC886 2509E63C 3EED9417 2E10F404
[2018/12/19 星期三 下午 3:11:10] 32A1480B 065B3116 A199EDD9 1344B117 08010061 E80FC000 08010060 E8120000
[2018/12/19 星期三 下午 3:11:10] LINK_STACK:
[2018/12/19 星期三 下午 3:11:10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:10] ***** SW COUNTERS *****
[2018/12/19 星期三 下午 3:11:10] Execute Count = 0x00000003
[2018/12/19 星期三 下午 3:11:10] Execute Addr = 0x7FFFF010
[2018/12/19 星期三 下午 3:11:10] End Addr = 0x7FFFF000
[2018/12/19 星期三 下午 3:11:10] CPU: 1 PID: 66 Comm: kworker/u8:3 Not tainted 4.9.88-imx_4.9.88_imx8qxp_beta2+g05f46d3 #56
[2018/12/19 星期三 下午 3:11:10] Hardware name: Freescale i.MX8QXP MEK (DT)
[2018/12/19 星期三 下午 3:11:10] Workqueue: galcore workqueue _TimerFunction [galcore]
[2018/12/19 星期三 下午 3:11:10] Call trace:
[2018/12/19 星期三 下午 3:11:10] [<ffff000008088600>] dump_backtrace+0x0/0x1b0
[2018/12/19 星期三 下午 3:11:10] [<ffff0000080887c4>] show_stack+0x14/0x20
[2018/12/19 星期三 下午 3:11:10] [<ffff0000082cb30c>] dump_stack+0x84/0xa8
[2018/12/19 星期三 下午 3:11:10] [<ffff000000655a94>] gckOS_DumpCallStack+0xc/0x18 [galcore]
[2018/12/19 星期三 下午 3:11:10] [<ffff0000006791c8>] gckHARDWARE_DumpGPUState+0x6b0/0xa20 [galcore]
[2018/12/19 星期三 下午 3:11:10] [<ffff00000065bcc0>] _DumpState+0x18/0x40 [galcore]
[2018/12/19 星期三 下午 3:11:10] [<ffff00000065cb84>] gckKERNEL_Recovery+0xdc/0x158 [galcore]
[2018/12/19 星期三 下午 3:11:10] [<ffff00000065cd9c>] _MonitorTimerFunction+0x19c/0x1a8 [galcore]
[2018/12/19 星期三 下午 3:11:10] [<ffff000000652160>] _TimerFunction+0x10/0x18 [galcore]
[2018/12/19 星期三 下午 3:11:10] [<ffff0000080b3360>] process_one_work+0x1d8/0x360
[2018/12/19 星期三 下午 3:11:10] [<ffff0000080b3530>] worker_thread+0x48/0x4c0
[2018/12/19 星期三 下午 3:11:10] [<ffff0000080b94f8>] kthread+0xf8/0x100
[2018/12/19 星期三 下午 3:11:10] [<ffff0000080827a0>] ret_from_fork+0x10/0x30
[2018/12/19 星期三 下午 3:11:10] **** COMMAND BUF DUMP ****
[2018/12/19 星期三 下午 3:11:10] Submitted commit stamp = 2
[2018/12/19 星期三 下午 3:11:10] Executed commit stamp = -1
[2018/12/19 星期三 下午 3:11:10] DMA Address 0x7FFFF010, memory around:
[2018/12/19 星期三 下午 3:11:10] User Command Buffer:
[2018/12/19 星期三 下午 3:11:10] 7FFFF000 : 10000000 00000002 40000002 7FFFF000 4000000C 7FFFF020 40000002 7FFFF010
[2018/12/19 星期三 下午 3:11:10] 7FFFF020 : 40000004 7FFFF028 08010061 FFFFFF7F 08010E02 30000701 48000000 30000701
[2018/12/19 星期三 下午 3:11:10] 7FFFF040 : 400007F7 7FFFF048 40000738 7FFB9000 40000002 7FFFF048 40000003 7FFFF068
[2018/12/19 星期三 下午 3:11:10] 7FFFF060 : 40000002 7FFFF058 08010E01 00000040 400000EF 7FF980C8 40000002 7FFFF070
[2018/12/19 星期三 下午 3:11:10] 7FFFF080 : 40000006 7FFFF090 40000002 7FFFF080 08010E01 00000041 380000C8 FFFFFEFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF0A0 : 40000002 7FFFF098 FFFFFFFF FFFFFFFF FFFFFFFF FFFF77FF FFFFEFFF 7F7FFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF0C0 : FFFEF7FF FFFF7FFF FFFFFFFF FFFFF7FF FFFFFF7F FFFFF7FF FFFFFEEF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF0E0 : FFFFFFFF FFFFFFFF FFFFFFFF FDFFFFFF FFFFFFFF FFFF6FFD FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF100 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFE FFFFFFFF FFFFFFEF FFFFF7F7
[2018/12/19 星期三 下午 3:11:10] 7FFFF120 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFF7F FFFFFFFF FFFFFFFF 7F7FFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF140 : FFFFFFFF FFFFFFFF FFFFFFF7 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFEFF FFFFFFFE
[2018/12/19 星期三 下午 3:11:10] 7FFFF160 : FEFFFBFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFF3 FFF7FFFF FFFF7FFF FFFF7FFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF180 : FFFFFFFF FFFFFFFF FFFFFFFF FFFF7FFF FFFFFFFF FFEFFFFE FFFFFFFF FFFFEFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF1A0 : FFFFFEFF FFFFFFFF FFFFFFFE FFFFFFFF FFFFFFFD FFFFFFF7 FFFF7EFF 7FFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF1C0 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFF7 FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF1E0 : FFFFFFEF EFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FF7F7FFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF200 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFDF FFFFFFFF FFFFFFFF FFFFF7FF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF220 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFBFFF FFFFFFFF FFFFFFFF FFFFFFFF 7F7FFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF240 : FFFFFFFF FFFF7FFE FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF260 : FFFFFFFF FFFFFFFF FFFFFFFF FFFF77FD FFFFFFFF FFFF7FFF FFFFFFFF 7F7FFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF280 : FFFF7FFF 7FFFFEFF F7FFFFF7 FFEFFFFF FF7FFFFF FFFFFFFF FFFFFFFF FFFFEFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF2A0 : FFFFF7FF FFFFFFEF FFFFFFFF FFFFFFFF FFFFFFEF FFFEFFFF FFFFFFFF F7FFF7FF
[2018/12/19 星期三 下午 3:11:10] 7FFFF2C0 : EFF7FFFE FFFFFFFF FFFFF7FF FFFFFFFF FFFFFFFF FFFFFFFF 7FFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF2E0 : FFFF7FFF FFFFFFFF FFFFFFFF FFFFFF7F FFFFFFFF FFFFFFFF FFFFF77F FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF300 : FFFEFFFF FFFFFFFF FFFFFDFF FFFFFFFF FFFFFFFF FFF7FFFF FFFFFEFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF320 : FFFFFFFF FFFFFFFF 7FFFFFFF FFFFFFFF FFFFFFFF FFFFFF7F FFFFFF7F FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF340 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFEFFF FFFFFEFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF360 : FEFFFFFF 7FFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FF7F7FFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF380 : FFFFFFFF FFFFFFFF FFFFFF7F FFFFFFF7 FFFFFFFF FFFF7FFF FFFFFFFF FFFFFFFE
[2018/12/19 星期三 下午 3:11:10] 7FFFF3A0 : FFFFFFFF FFFFEFFF FFFFFFFF EFFFEDFF BFFFF7FF FFFFFFFF FFFFFFFF FD7FF77F
[2018/12/19 星期三 下午 3:11:10] 7FFFF3C0 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF3E0 : FFFFFFFE FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7F7F7FFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF400 : FFFFFFFF FFFFF7FF FFFFFFFF FFFFEFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF420 : FFFFFEFF FFFFFFFB FFFF7FFF FFFF7FBF FFFFFFFF FFFFFFFF FFFFFFFE 7F7FFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF440 : FFFFFFFF FFFFFFFF FFFFEFFF FFFFFFFF FFFFFFFF FFFFFEFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF460 : FFFFFFFF FFFFFFFF FFFFFFFF FFF7FFFF FFFFFFFF FFFFFFFF FFFFFFFF 7FFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF480 : FFFFF7FF FFFFBFFF FFFFFFFF FFFF7FFF FFFFFFFF FFFF7FEF FFFFFFFF FFFFE7FF
[2018/12/19 星期三 下午 3:11:10] 7FFFF4A0 : FFFFFF7F FFFFFFFF FFFFEEFF FFFFFFFF FFFFFFFF FFFFFFFE FFFFFFEF 7F7F7FFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF4C0 : FFFFEFFF FFFFFFF7 FFFFF7FF FFFFFFFE EFFF7FFF FFFFFF7F FFFFFFFF FFFF67FE
[2018/12/19 星期三 下午 3:11:10] 7FFFF4E0 : FFFFFFEF FFFFF7EF FFFF7FFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFBFFF FF7FF7FF
[2018/12/19 星期三 下午 3:11:10] 7FFFF500 : FFFFFFF7 EFFFFFFF DFFFFEFF FFFFF7FF FFFFFFFF FFFFFFFF FFFFFF7F FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF520 : FFFFFFFF FFFFFFFF FFFFEFFF FFFFEFFF FFFFFFEF FFFFFFFF FFFFFFFF FE7FF7FF
[2018/12/19 星期三 下午 3:11:10] 7FFFF540 : FFFFBFFF FFFFFFFF F7FFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFEF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF560 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFF7F FBFFFFFF FFFFFFFF F7FFFFFF FFFFFBFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF580 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFEFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF5A0 : FFFFFFFF FFFFFFFF FFFFFFFF FFF7FFFF FFFFFFFF FFFFFFFE FFFFFFFF 7FFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF5C0 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFF7FF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFEF
[2018/12/19 星期三 下午 3:11:10] 7FFFF5E0 : FFFFFFFF FFFFFFFF F7F77FFF FFFFFFFE FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF600 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFF7 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF620 : FFFFFF7F FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFE FFFFFFFF 7F7F7FFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF640 : FFFF7FFF FFFF7FFF FFFFF7FF FFFFFFFF FFFFFFFF FFFFFFFF FFFF7F7F FFEFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF660 : FFFFFF7F FFFFFF7F FFFFFFEF FFFFFFFF FFFFF7FF FFFFFFFF FFFFFFFF 7FFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF680 : FFFFFFFF FFFFFFFF FFF7FFFF FF7FFFFF FFFFFFFF FFFFFEFF FFFFFFFE FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF6A0 : FFFFFFF7 FFFFFFFF FFFFFFFF FFFFFF7F FFFFFFFF FFFFFFFF FFFFFFFF 7FFFFCFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF6C0 : FFFFEFFF FFFFFFFF FFFFFFFE FFFFFFFF FFFFFFFF FFFEFFFF FFFFFFFF FFFFEDEF
[2018/12/19 星期三 下午 3:11:10] 7FFFF6E0 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFB FFFFFFFF FFFFFFFF FFFFFFFF FFFFF7FF
[2018/12/19 星期三 下午 3:11:10] 7FFFF700 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFB FFFFFFFF FFFDFFFF FFFFFFFF FFFFFFDF
[2018/12/19 星期三 下午 3:11:10] 7FFFF720 : FFFFFFFE FFFFFFF7 FFFF7FFF FFFFFFFF FFFFFFFF FFFFFF7F FFFFFFFF 7FFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF740 : FFFF7FFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFE EFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF760 : FFFFFFFF FFFFFFFF FFEFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF780 : FFFFFFFF FFFFFF7F FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF7A0 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7F7FEFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF7C0 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFE FFFFFEFF FFFFFEFF F7FFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF7E0 : DFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7FFFFEFF FF7FFFDF
[2018/12/19 星期三 下午 3:11:10] 7FFFF800 : FFFFFFFE FFFFFFFF FFFFFFFF FFFFFFFF FEFFFF7E FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF820 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFEFFFF7 FFFFFFFF FFFFFFFF FFFF7FFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF840 : FFFFFFFF FFFFFF7F FFFFFFFF FFFFFFFF FF7FFFFF FFFFFFEF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF860 : FFFFFFFF FFFFFFFF FFF7FFFF FFFFFFFB FFFFFFFF FFFFFFFF FFFFFFFE 7FFF7FFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF880 : FFFFFFEF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF8A0 : FFFFFFFF FFFFFFEF FFFFFFFF FFFFFFFF FFFFFFFB FFFFFFFF FFFFFFF7 7F7F7FFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF8C0 : FFFFFFDF FFFFF7FF FFFFFFFF FFFFFEFF 7FFFFFFF FFFFFFFF FFFFFFFE FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF8E0 : FFFFFFF7 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFF7FFFE FFFFFFFF FFFFBFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF900 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFF7FF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF920 : EFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7FFFFFFF FFFFFFFF FF7FFF7F
[2018/12/19 星期三 下午 3:11:10] 7FFFF940 : FFFFFFFF FFFFFFFF FFFFFDFF FFFFFFFF FF7FFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF960 : FFFFFFFF FFFFF7FF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7FFFFF7F
[2018/12/19 星期三 下午 3:11:10] 7FFFF980 : FFFFFFFF FFFFBFFF FFFF7FFF FFFFFFFF FFF7FFFF 7FFFFFFF EFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF9A0 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF EFFFFEFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF9C0 : FFFFFFFF FFFFFFFF FFFFFDFF FFFFFFFF FFFFF7FF FFFFFFFF FFFFFFFF FFFFEFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFF9E0 : FFFFFFFE FFFFFFFF FFFFFFFF FFFFFFFF FFFFF7FF FFFEFFFF FFFFFFFD 7FFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFFA00 : FFFFF7FF FFFFFFFF FFFFFEFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FEFFFFC7
[2018/12/19 星期三 下午 3:11:10] 7FFFFA20 : FFFFFFEF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFF7FFF FF7FFFDF
[2018/12/19 星期三 下午 3:11:10] 7FFFFA40 : FF7FFFFF FFFFFFFF FFFF7FFF FFFFFFFF FFFFFF7F FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFFA60 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFF7FFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFFA80 : FFFFFFFF FFFFFFFF FFFFF7EF FFFFFFFF FFFFFFEF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFFAA0 : FFFFFFFF FFFFFFFF FFFFFF7F FFFFFFFE FFFFFFFF FFFFFFFF FFFFFFFF 7F7FFFDF
[2018/12/19 星期三 下午 3:11:10] 7FFFFAC0 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFF7FFF FFFF7FFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFFAE0 : FFFFFFFF FFFFFFF7 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7F7FFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFFB00 : FFFFFEFF FFFFFFFF FFFFFFEF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFFB20 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFEFFF DFFFFFFE FFFFFFFF FF7FFFFF
[2018/12/19 星期三 下午 3:11:10] 7FFFFB40 : FEFFF7FF FFFFFF7F FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFBFF
[2018/12/19 星期三 下午 3:11:10] 7FFFFB60 : FFFFFFFF FFFFFEEF FFFFFFFF FFFFFFEF FFFFFFFF FFFFFFFF FFFFFFFE FF7FFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFB80 : EFFFFFFF FFF7FFFF FFFFFF7F FFFFEFFF FFFF7FFF FFFFFFFF FFFFFFFF FFFFFFEF
[2018/12/19 星期三 下午 3:11:11] 7FFFFBA0 : FFFFEFFF FFFFFF7F FFFFFFFF FFFFFFFE FFFFFFEF FFFFFFFF FFFFFFFF FEFFFF7F
[2018/12/19 星期三 下午 3:11:11] 7FFFFBC0 : FFFFFFFF FFFFFFFF FFFFFFF7 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFEFF FFF7FFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFBE0 : FFFFFFFF FFFFFFEF FFFFFF7E FFFFFFFF FFFFFFFF FFFFFF7F FFFFFFFE 7FFFFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFC00 : FFFFFFF7 FFFFFFFF FFFFFFFF EFFF7FFF FFFF7DFF FFFFEF7F FFFFFFFF FFF7FFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFC20 : FFFFF7FF FFFFEFFF FFFFFFFE FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFF7FF
[2018/12/19 星期三 下午 3:11:11] 7FFFFC40 : FFF7FFFF FFFFFFEF FFFFFFEE FFFFEF7F FFFFFFFF FFFFFF7F FFFFFFFF FFF7F7FF
[2018/12/19 星期三 下午 3:11:11] 7FFFFC60 : FFFFFFFF EFFFFFF7 FFF7FFFF FFFF7FFF FFFFFFFF FFFFFFFF FF7FF7FF FFFFFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFC80 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFEFF F7FFFFF7 EFFFFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFCA0 : FFFFFBFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFF7FFF FFFFF7FD FF7FFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFCC0 : FFFF7F7F FFFFFFFF FFFFFFFF FFFFFFFE FFFFFFEF FFFF7FFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFCE0 : FFFFFFFD FFFFFFF7 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7F7FFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFD00 : FFFFFEFF FFFFFFFF FFFFFFFF FFFF7FFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFEEF
[2018/12/19 星期三 下午 3:11:11] 7FFFFD20 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFEFFF FFFFFFFF FFFFFB5F FFF7FFFF 7FFFF7F7
[2018/12/19 星期三 下午 3:11:11] 7FFFFD40 : FFFFF7FF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFF7 FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFD60 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFEF FFFFFFFF 7F7F6DFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFD80 : FFFFFFFF FFFF6FFF F7FFFFFF FFFFFFFF FFFFFFFF FFFFFDFF FFFFFFFF EFFFFF7F
[2018/12/19 星期三 下午 3:11:11] 7FFFFDA0 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FF7FFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFDC0 : FF7FFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFDE0 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7FF77F7F
[2018/12/19 星期三 下午 3:11:11] 7FFFFE00 : FFFFEFFF FFFFFFFF FFFFFFFF FFFFFFFF F7FFFFFF FF7FFFFF FFF7DFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFE20 : FFFFFFFF FFFFFEFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFF7FF FFFFFFFF FFF7FF7F
[2018/12/19 星期三 下午 3:11:11] 7FFFFE40 : FFFFFFFF FFFFFFFF FFDFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FEFFFFFF FFFFFF7F
[2018/12/19 星期三 下午 3:11:11] 7FFFFE60 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7FFFFFFF FFFFFFFF FFFFFFF7 FFFF7FFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFE80 : FFFF7FFF FFFFFFFF FFFFFFFF FFFFFF7F FFFFFDFF FEFFF7FF FFFFFFFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFEA0 : FFFFFFFF FFFFFFF7 FFFFFFFF FFFFFDFF FFFFFFFF FFFFBFFF FFFFFF7F FF7F7FFD
[2018/12/19 星期三 下午 3:11:11] 7FFFFEC0 : FFFFF7DF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFF7FFF FFFFFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFEE0 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFEFF FFFFFFFF FFEFFFFF 7FFFFFFD
[2018/12/19 星期三 下午 3:11:11] 7FFFFF00 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFE FFFFFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFF20 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7F7F7FFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFF40 : FFFFFFFF FEFFFFFF FFFFFEFF FFFFFF7F FFFFFFFF FFFFFFFF FFFFFFF7 FFFFFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFF60 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF EF7FFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFF80 : FFFFF7FF FFFFFFFF FFFFFFEF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFE FFFF7FFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFFA0 : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFEF FFFFFFFF FFFFFFFF 7FFFFFFF FF7FFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFFFFC0 : FFFFEFFF FFFFFFFF FFFFFFFF FFFFF7FF FFFFFFEF FFFFEFFF FFFFFFFF FFFFEF7F
[2018/12/19 星期三 下午 3:11:11] 7FFFFFE0 : FFFFFFFE FFFFFEFF FFFFFFFF FFFFFFF7 FFFFFFFF FFFFFFFF FFFFFFFF 7F7FF7FF
[2018/12/19 星期三 下午 3:11:11] Dump Level is 2, dump 4 valid record in link queue:
[2018/12/19 星期三 下午 3:11:11] Buffer [E8124000 - E8124030] not found, may be freed
[2018/12/19 星期三 下午 3:11:11] Context Buffer: 40000738, 7FFB9000 PID:879 weston
[2018/12/19 星期三 下午 3:11:11] 7FFB9000 : 08010E00 00000000 08010E02 00000701 48000000 00000701 08010E03 00000C27
[2018/12/19 星期三 下午 3:11:11] 7FFB9020 : 08010E03 00000010 08010E02 00000701 48000000 00000701 08010594 00000001
[2018/12/19 星期三 下午 3:11:11] 7FFB9040 : 08010E02 00000701 48000000 00000701 08010218 00000000 0801021A 00000011
[2018/12/19 星期三 下午 3:11:11] 7FFB9060 : 08010218 00000001 0801021A 00000021 08010E02 00000701 48000000 00000701
[2018/12/19 星期三 下午 3:11:11] 7FFB9080 : 08010E05 00000001 08030E06 00000000 00000000 00000000 08020E0A 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB90A0 : 00000000 DEADDEAD 08020E0D 00000000 00000000 DEADDEAD 08010E15 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB90C0 : 08010E13 00000000 08100180 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB90E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9100 : 00000000 00000000 00000000 DEADDEAD 084001B0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9120 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9140 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9160 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9180 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB91A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB91C0 : 00000000 00000000 00000000 00000000 00000000 3F800000 3F800000 3F800000
[2018/12/19 星期三 下午 3:11:11] 7FFB91E0 : 3F800000 3F800000 3F800000 3F800000 3F800000 3F800000 3F800000 3F800000
[2018/12/19 星期三 下午 3:11:11] 7FFB9200 : 3F800000 3F800000 3F800000 3F800000 3F800000 DEADDEAD 08305180 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9220 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9240 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9260 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9280 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB92A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB92C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:11] 7FFB92E0 : 08020191 00000000 00000000 DEADDEAD 0803019D 00000000 00000000 FFFFFFFF
[2018/12/19 星期三 下午 3:11:11] 7FFB9300 : 08010218 00000000 0802021A 00000000 00000000 DEADDEAD 08010C13 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9320 : 0801040A 00000000 08010224 00000000 08010413 00000000 08030201 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9340 : 00000001 00000000 0801020C 00000000 08080204 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9360 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 0C020280 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9380 : 00000000 DEADDEAD 08010282 00000000 0C020283 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:11] 7FFB93A0 : 08030285 00000000 00000000 3F000000 0806028A 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB93C0 : 00000000 00000000 00000000 DEADDEAD 080102A0 00000000 0C0102A1 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB93E0 : 080102A3 00000000 080102A2 00000000 08100290 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9400 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9420 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 08030E80 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9440 : 00000000 00000000 0C040300 00000000 00000000 45000000 45000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:11] 7FFB9460 : 08040304 00000000 00000000 00000000 42000000 DEADDEAD 0C020308 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9480 : 00000000 DEADDEAD 08010380 000000F1 08040384 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB94A0 : 00000000 DEADDEAD 08010381 00000000 08100390 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB94C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB94E0 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 08010382 17000031
[2018/12/19 星期三 下午 3:11:11] 7FFB9500 : 08010389 00000000 08010388 00000000 08010383 00000000 08040401 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9520 : 00000000 00000000 00000000 DEADDEAD 0802040C 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:11] 7FFB9540 : 08020410 00000000 00000000 DEADDEAD 0801040B 00000000 0801040E 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9560 : 08010415 00000000 080C0800 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9580 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:11] 7FFB95A0 : 080C0810 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB95C0 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 080C0820 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB95E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9600 : 00000000 00000000 00000000 DEADDEAD 080C0830 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9620 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9640 : 00000000 DEADDEAD 080C0840 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9660 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:11] 7FFB9680 : 080C0850 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB96A0 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 080C0860 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB96C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB96E0 : 00000000 00000000 00000000 DEADDEAD 080C0870 00321000 00321000 00321000
[2018/12/19 星期三 下午 3:11:11] 7FFB9700 : 00321000 00321000 00321000 00321000 00321000 00321000 00321000 00321000
[2018/12/19 星期三 下午 3:11:11] 7FFB9720 : 00321000 DEADDEAD 080C0880 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9740 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:11] 7FFB9760 : 080C0890 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9780 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 080C0900 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB97A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB97C0 : 00000000 00000000 00000000 DEADDEAD 080C0910 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB97E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9800 : 00000000 DEADDEAD 080C0920 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9820 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:11] 7FFB9840 : 080C0930 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9860 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 080C0940 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9880 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB98A0 : 00000000 00000000 00000000 DEADDEAD 080C0950 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB98C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB98E0 : 00000000 DEADDEAD 080C0960 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9900 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:11] 7FFB9920 : 080C0970 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9940 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 080C0980 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9960 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9980 : 00000000 00000000 00000000 DEADDEAD 080C0990 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB99A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB99C0 : 00000000 DEADDEAD 080C09A0 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB99E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:11] 7FFB9A00 : 080C09B0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9A20 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 080C09C0 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9A40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9A60 : 00000000 00000000 00000000 DEADDEAD 080C09D0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9A80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9AA0 : 00000000 DEADDEAD 080E0B00 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9AC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9AE0 : 00000000 DEADDEAD 080E0B10 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9B00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9B20 : 00000000 DEADDEAD 080E0B20 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9B40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9B60 : 00000000 DEADDEAD 080E0B30 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9B80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9BA0 : 00000000 DEADDEAD 080E0B40 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9BC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9BE0 : 00000000 DEADDEAD 080E0B50 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9C00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9C20 : 00000000 DEADDEAD 080E0B60 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9C40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9C60 : 00000000 DEADDEAD 080E0B70 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9C80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9CA0 : 00000000 DEADDEAD 080E0B80 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9CC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:11] 7FFB9CE0 : 00000000 DEADDEAD 080E0B90 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9D00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9D20 : 00000000 DEADDEAD 080E0BA0 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9D40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9D60 : 00000000 DEADDEAD 080E0BB0 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9D80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9DA0 : 00000000 DEADDEAD 09404000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9DC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9DE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9E00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9E20 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9E40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9E60 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9E80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9EA0 : 00000000 00000000 00000000 20000000 20000000 20000000 20000000 20000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9EC0 : 20000000 20000000 20000000 20000000 20000000 20000000 20000000 20000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9EE0 : 20000000 20000000 20000000 20000000 20000000 20000000 20000000 20000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9F00 : 20000000 20000000 20000000 20000000 20000000 20000000 20000000 20000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9F20 : 20000000 20000000 20000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9F40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9F60 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9F80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9FA0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9FC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFB9FE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA000 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA020 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA040 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA060 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA080 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA0A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA0C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA0E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA100 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA120 : 00000000 00000000 00000000 00321000 00321000 00321000 00321000 00321000
[2018/12/19 星期三 下午 3:11:12] 7FFBA140 : 00321000 00321000 00321000 00321000 00321000 00321000 00321000 00321000
[2018/12/19 星期三 下午 3:11:12] 7FFBA160 : 00321000 00321000 00321000 00321000 00321000 00321000 00321000 00321000
[2018/12/19 星期三 下午 3:11:12] 7FFBA180 : 00321000 00321000 00321000 00321000 00321000 00321000 00321000 00321000
[2018/12/19 星期三 下午 3:11:12] 7FFBA1A0 : 00321000 00321000 00321000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA1C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA1E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA200 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA220 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA240 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA260 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA280 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA2A0 : 00000000 00000000 00000000 DEADDEAD 080E4200 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA2C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA2E0 : 00000000 00000000 00000000 DEADDEAD 080E4210 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA300 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA320 : 00000000 00000000 00000000 DEADDEAD 080E4220 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA340 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA360 : 00000000 00000000 00000000 DEADDEAD 080E4230 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA380 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA3A0 : 00000000 00000000 00000000 DEADDEAD 080E4240 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA3C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA3E0 : 00000000 00000000 00000000 DEADDEAD 080E4250 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA400 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA420 : 00000000 00000000 00000000 DEADDEAD 080E4260 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA440 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA460 : 00000000 00000000 00000000 DEADDEAD 080E4270 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA480 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA4A0 : 00000000 00000000 00000000 DEADDEAD 080E4280 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA4C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA4E0 : 00000000 00000000 00000000 DEADDEAD 080E4290 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA500 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA520 : 00000000 00000000 00000000 DEADDEAD 080E42A0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA540 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA560 : 00000000 00000000 00000000 DEADDEAD 080E42B0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA580 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA5A0 : 00000000 00000000 00000000 DEADDEAD 080E42C0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA5C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA5E0 : 00000000 00000000 00000000 DEADDEAD 080E42D0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA600 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA620 : 00000000 00000000 00000000 DEADDEAD 080E42E0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA640 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA660 : 00000000 00000000 00000000 DEADDEAD 080E42F0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA680 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA6A0 : 00000000 00000000 00000000 DEADDEAD 080E4300 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA6C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA6E0 : 00000000 00000000 00000000 DEADDEAD 080E4310 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA700 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA720 : 00000000 00000000 00000000 DEADDEAD 080E4320 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA740 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA760 : 00000000 00000000 00000000 DEADDEAD 080E4330 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA780 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA7A0 : 00000000 00000000 00000000 DEADDEAD 080E4340 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA7C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA7E0 : 00000000 00000000 00000000 DEADDEAD 080E4350 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA800 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA820 : 00000000 00000000 00000000 DEADDEAD 080E4360 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA840 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA860 : 00000000 00000000 00000000 DEADDEAD 080E4370 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA880 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA8A0 : 00000000 00000000 00000000 DEADDEAD 080E4380 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA8C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA8E0 : 00000000 00000000 00000000 DEADDEAD 080E4390 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA900 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA920 : 00000000 00000000 00000000 DEADDEAD 080E43A0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA940 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA960 : 00000000 00000000 00000000 DEADDEAD 080E43B0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA980 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA9A0 : 00000000 00000000 00000000 DEADDEAD 080E43C0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA9C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBA9E0 : 00000000 00000000 00000000 DEADDEAD 080E43D0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAA00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAA20 : 00000000 00000000 00000000 DEADDEAD 080E43E0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAA40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAA60 : 00000000 00000000 00000000 DEADDEAD 080E43F0 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAA80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAAA0 : 00000000 00000000 00000000 DEADDEAD 084041C0 00000F00 00000F00 00000F00
[2018/12/19 星期三 下午 3:11:12] 7FFBAAC0 : 00000F00 00000F00 00000F00 00000F00 00000F00 00000F00 00000F00 00000F00
[2018/12/19 星期三 下午 3:11:12] 7FFBAAE0 : 00000F00 00000F00 00000F00 00000F00 00000F00 00000F00 00000F00 00000F00
[2018/12/19 星期三 下午 3:11:12] 7FFBAB00 : 00000F00 00000F00 00000F00 00000F00 00000F00 00000F00 00000F00 00000F00
[2018/12/19 星期三 下午 3:11:12] 7FFBAB20 : 00000F00 00000F00 00000F00 00000F00 00000F00 00030000 00030000 00030000
[2018/12/19 星期三 下午 3:11:12] 7FFBAB40 : 00030000 00030000 00030000 00030000 00030000 00030000 00030000 00030000
[2018/12/19 星期三 下午 3:11:12] 7FFBAB60 : 00030000 00030000 00030000 00030000 00030000 00030000 00030000 00030000
[2018/12/19 星期三 下午 3:11:12] 7FFBAB80 : 00030000 00030000 00030000 00030000 00030000 00030000 00030000 00030000
[2018/12/19 星期三 下午 3:11:12] 7FFBABA0 : 00030000 00030000 00030000 00030000 00030000 DEADDEAD 08404480 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBABC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBABE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAC00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAC20 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAC40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAC60 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAC80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBACA0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:12] 7FFBACC0 : 08804400 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBACE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAD00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAD20 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAD40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAD60 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAD80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBADA0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBADC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBADE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAE00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAE20 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAE40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAE60 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:12] 7FFBAE80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBAEA0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBAEC0 : 00000000 DEADDEAD 082044C0 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBAEE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBAF00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBAF20 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBAF40 : 00000000 00000000 00000000 DEADDEAD 08804140 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBAF60 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBAF80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBAFA0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBAFC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBAFE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB000 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB020 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB040 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB060 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB080 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB0A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB0C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB0E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB100 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB120 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB140 : 00000000 00000000 00000000 00000000 00000000 DEADDEAD 08105300 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB160 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB180 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:13] 7FFBB1A0 : 08070240 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB1C0 : 08010249 00000000 08010247 00000000 08060250 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB1E0 : 00000000 00000000 00000000 DEADDEAD 0804021D 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB200 : 00000000 DEADDEAD 08010409 00000100 08010219 00000000 0800C000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB220 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB240 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB260 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB280 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB2A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB2C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB2E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB300 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB320 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB340 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB360 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB380 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB3A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB3C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB3E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB400 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB420 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB440 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB460 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB480 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB4A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB4C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB4E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB500 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB520 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB540 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB560 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB580 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB5A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB5C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB5E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB600 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB620 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB640 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB660 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB680 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB6A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB6C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB6E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB700 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB720 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB740 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB760 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB780 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB7A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB7C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB7E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB800 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB820 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB840 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB860 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB880 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB8A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB8C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB8E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB900 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB920 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB940 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB960 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB980 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB9A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB9C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBB9E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBA00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBA20 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBA40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBA60 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBA80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBAA0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBAC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBAE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBB00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBB20 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBB40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBB60 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBB80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBBA0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBBC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBBE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBC00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBC20 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBC40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBC60 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBC80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBCA0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBCC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBCE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBD00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBD20 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBD40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBD60 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBD80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBDA0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBDC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBDE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBE00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBE20 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBE40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBE60 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBE80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBEA0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBEC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBEE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBF00 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBF20 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBF40 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBF60 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBF80 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBFA0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBFC0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBBFE0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBC000 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBC020 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:13] 7FFBC040 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC060 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC080 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC0A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC0C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC0E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC100 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC120 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC140 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC160 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC180 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC1A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC1C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC1E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC200 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:14] 7FFBC220 : 0900C400 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC240 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC260 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC280 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC2A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC2C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC2E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC300 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC320 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC340 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC360 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC380 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC3A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC3C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC3E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC400 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC420 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC440 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC460 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC480 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC4A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC4C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC4E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC500 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC520 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC540 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC560 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC580 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC5A0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC5C0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC5E0 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC600 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC620 : 00000000 DEADDEAD 08010221 00000000 08040500 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC640 : 00000000 DEADDEAD 08070505 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC660 : 00000000 00000000 0801050D 00000000 08020515 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:14] 7FFBC680 : 08010528 00000000 0804052A FFFFFFFF FFFFFFFF 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:14] 7FFBC6A0 : 08010529 000E400C 08030560 00000000 00000000 00000000 0801052E 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC6C0 : 0801040F 76543210 08020518 00000000 00000000 DEADDEAD 08020520 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC6E0 : 00000000 DEADDEAD 08020540 00000000 00000000 DEADDEAD 08020548 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC700 : 00000000 DEADDEAD 08020550 00000000 00000000 DEADDEAD 08025200 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC720 : 00000000 DEADDEAD 08025208 00000000 00000000 DEADDEAD 08025210 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC740 : 00000000 DEADDEAD 08025218 00000000 00000000 DEADDEAD 08025220 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC760 : 00000000 DEADDEAD 08025228 00000000 00000000 DEADDEAD 08025230 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC780 : 00000000 DEADDEAD 08075240 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC7A0 : 00000000 00000000 0802052F 00000000 00000000 DEADDEAD 08010595 00200000
[2018/12/19 星期三 下午 3:11:14] 7FFBC7C0 : 08080596 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC7E0 : 00000000 DEADDEAD 080105A9 00000000 080105AB 00000000 080105AA 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC800 : 082005C8 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC820 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC840 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC860 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC880 : 00000000 DEADDEAD 080105AF 00000000 080705E9 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC8A0 : 00000000 00000000 00000000 00000000 080705F1 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC8C0 : 00000000 00000000 00000000 00000000 080705F9 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC8E0 : 00000000 00000000 00000000 00000000 08070681 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC900 : 00000000 00000000 00000000 00000000 08070689 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC920 : 00000000 00000000 00000000 00000000 08070691 00000000 00000000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC940 : 00000000 00000000 00000000 00000000 08010E18 00000006 080806A0 00000000
[2018/12/19 星期三 下午 3:11:14] 7FFBC960 : 00000000 00000000 00000000 00000000 00000000 00000000 00000000 DEADDEAD
[2018/12/19 星期三 下午 3:11:14] 7FFBC980 : 08010E02 00000701 48000000 00000701 40000014 7FF98020
[2018/12/19 星期三 下午 3:11:14] User Command Buffer: 40000014, 7FF98020 PID:879 weston
[2018/12/19 星期三 下午 3:11:14] 7FF98020 : 08010E03 00000C23 08010E03 00000C23 08010594 00000001 08010594 00000001
[2018/12/19 星期三 下午 3:11:14] 7FF98040 : 08010E05 00000001 08010380 00000001 0801028B 34000001 08010529 FFFFFBFF
[2018/12/19 星期三 下午 3:11:14] 7FF98060 : 08010383 00000000 080102A2 40000000 08010218 00001000 08010221 00000808
[2018/12/19 星期三 下午 3:11:14] 7FF98080 : 0801028A 00000011 08010E13 00000000 08010306 00000020 08010E03 00000C23
[2018/12/19 星期三 下午 3:11:14] 7FF980A0 : 40000005 7FFFF058
[2018/12/19 星期三 下午 3:11:14] User Command Buffer: 400000EF, 7FF980C8 PID:879 weston
[2018/12/19 星期三 下午 3:11:14] 7FF980C8 : 08010E03 00000002 0801FFFF 00000000 08010595 00000000 08010415 FFFF6FFF
[2018/12/19 星期三 下午 3:11:14] 7FF980E8 : 08010415 6FFFFFFF 08010415 F70FFFFF 08010415 FFF6FFFF 08010415 FFFFF6FF
[2018/12/19 星期三 下午 3:11:14] 7FF98108 : 08010415 FFFFFF7F 08010E02 00000701 48000000 00000701 08010218 20001001
[2018/12/19 星期三 下午 3:11:14] 7FF98128 : 0804C000 3A888889 00000000 00000000 00000000 00000000 0804C004 00000000
[2018/12/19 星期三 下午 3:11:14] 7FF98148 : BB360B61 00000000 00000000 00000000 0804C008 00000000 00000000 3F800000
[2018/12/19 星期三 下午 3:11:14] 7FF98168 : 00000000 00000000 0804C00C BF800000 3F800000 00000000 3F800000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FF98188 : 08010218 20001011 0804C4F8 00000000 00000000 00000000 3F800000 00000000
[2018/12/19 星期三 下午 3:11:14] 7FF981A8 : 08010218 20001011 0801C4FC 3F800000 08015180 E9E80240 08015190 00000010
[2018/12/19 星期三 下午 3:11:14] 7FF981C8 : 080151A0 00000000 08010180 08002088 080101E0 3F800000 08010208 00000000
[2018/12/19 星期三 下午 3:11:14] 7FF981E8 : 08020191 00000000 00000000 00000010 0801019D 00000000 0C020280 03C00000
[2018/12/19 星期三 下午 3:11:14] 7FF98208 : FE980000 3F800000 0C020283 03C00000 01680000 00000000 080102A0 38F01E06
[2018/12/19 星期三 下午 3:11:14] 7FF98228 : 0C0102A1 20000000 080102A3 00000000 0C040300 00000000 00000000 07800000
[2018/12/19 星期三 下午 3:11:14] 7FF98248 : 02D01111 00000000 0C010308 0780FFFF 0C010309 02D0FFFF 08010E03 00000002
[2018/12/19 星期三 下午 3:11:14] 7FF98268 : 0801050B 05100F10 0802052A 6E4CA280 5D7F91B3 00000000 08020518 E8800000
[2018/12/19 星期三 下午 3:11:14] 7FF98288 : E8800000 00000000 0801050D 00001E00 08010529 3FFFFFFF 08010529 FFFFFE7F
[2018/12/19 星期三 下午 3:11:14] 7FF982A8 : 08030508 00000070 00000000 05110511 0801052C 00000000 0801052D 00000000
[2018/12/19 星期三 下午 3:11:14] 7FF982C8 : 08010528 0000FDFF 08010529 FFFFFBFF 08010E03 00000001 08040500 01040700
[2018/12/19 星期三 下午 3:11:14] 7FF982E8 : 00000000 3F800000 00000000 00000000 08010382 00000031 08010515 00000000
[2018/12/19 星期三 下午 3:11:14] 7FF98308 : 08010388 00007000 08010282 3F000000 08010285 3F000000 08020506 00070007
[2018/12/19 星期三 下午 3:11:14] 7FF98328 : 00000000 00000000 08010E03 00000003 08010E02 00000701 48000000 00000701
[2018/12/19 星期三 下午 3:11:14] 7FF98348 : 08010529 F0FFFFFF 08010E06 00300000 08010286 3F000000 0803028D 00412000
[2018/12/19 星期三 下午 3:11:14] 7FF98368 : 3F000000 3F000000 08010202 00000101 08010204 00000000 08010203 00000002
[2018/12/19 星期三 下午 3:11:14] 7FF98388 : 08010219 00000000 08010218 00000000 0801021D 00000000 0801021E 00000002
[2018/12/19 星期三 下午 3:11:14] 7FF983A8 : 0801021B E9E80100 08010218 00001000 0801021A 00000011 08010224 00000002
[2018/12/19 星期三 下午 3:11:14] 7FF983C8 : 08010380 00000001 08010401 00000001 0801040B 00000000 0801040D 0000003F
[2018/12/19 星期三 下午 3:11:14] 7FF983E8 : 0801040E 00000000 08010E08 00000000 08010E0D 00000000 08010E0A 00000000
[2018/12/19 星期三 下午 3:11:14] 7FF98408 : 08010E0B 00000000 08010410 00000000 08010411 00000000 08010E0E 00000000
[2018/12/19 星期三 下午 3:11:14] 7FF98428 : 08010E15 00000000 08010403 00000002 08010409 0000013E 08010218 00000010
[2018/12/19 星期三 下午 3:11:14] 7FF98448 : 0801021F 00000000 08010220 00000001 0801040A E9E80200 08010218 20001011
[2018/12/19 星期三 下午 3:11:14] 7FF98468 : 0801021A 00000021 08010413 00000001 08030402 00001F01 00000002 00000002
[2018/12/19 星期三 下午 3:11:14] 7FF98488 : 0801028C 00000000 08010E07 00000000 0801040C 00000000 0801040B 00000000
[2018/12/19 星期三 下午 3:11:14] 7FF984A8 : 0801020C 0F3F0240 08010201 00000001 08010223 00000000 08010412 00000000
[2018/12/19 星期三 下午 3:11:14] 7FF984C8 : 08014000 0000E000 080140E0 CCCCCCCC 080141E0 CCCCCCCC 08014001 0000E000
[2018/12/19 星期三 下午 3:11:14] 7FF984E8 : 080140E1 CCCCCCCC 080141E1 CCCCCCCC 08014002 0000E000 080140E2 CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF98508 : 080141E2 CCCCCCCC 08014003 0000E000 080140E3 CCCCCCCC 080141E3 CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF98528 : 08014004 0000E000 080140E4 CCCCCCCC 080141E4 CCCCCCCC 08014005 0000E000
[2018/12/19 星期三 下午 3:11:14] 7FF98548 : 080140E5 CCCCCCCC 080141E5 CCCCCCCC 08014006 0000E000 080140E6 CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF98568 : 080141E6 CCCCCCCC 08014007 0000E000 080140E7 CCCCCCCC 080141E7 CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF98588 : 08014008 0000E000 080140E8 CCCCCCCC 080141E8 CCCCCCCC 08014009 0000E000
[2018/12/19 星期三 下午 3:11:14] 7FF985A8 : 080140E9 CCCCCCCC 080141E9 CCCCCCCC 0801400A 0000E000 080140EA CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF985C8 : 080141EA CCCCCCCC 0801400B 0000E000 080140EB CCCCCCCC 080141EB CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF985E8 : 0801400C 0000E000 080140EC CCCCCCCC 080141EC CCCCCCCC 0801400D 0000E000
[2018/12/19 星期三 下午 3:11:14] 7FF98608 : 080140ED CCCCCCCC 080141ED CCCCCCCC 0801400E 0000E000 080140EE CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF98628 : 080141EE CCCCCCCC 0801400F 0000E000 080140EF CCCCCCCC 080141EF CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF98648 : 08014010 0000E000 080140F0 CCCCCCCC 080141F0 CCCCCCCC 08014011 0000E000
[2018/12/19 星期三 下午 3:11:14] 7FF98668 : 080140F1 CCCCCCCC 080141F1 CCCCCCCC 08014012 0000E000 080140F2 CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF98688 : 080141F2 CCCCCCCC 08014013 0000E000 080140F3 CCCCCCCC 080141F3 CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF986A8 : 08014014 0000E000 080140F4 CCCCCCCC 080141F4 CCCCCCCC 08014015 0000E000
[2018/12/19 星期三 下午 3:11:14] 7FF986C8 : 080140F5 CCCCCCCC 080141F5 CCCCCCCC 08014016 0000E000 080140F6 CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF986E8 : 080141F6 CCCCCCCC 08014017 0000E000 080140F7 CCCCCCCC 080141F7 CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF98708 : 08014018 0000E000 080140F8 CCCCCCCC 080141F8 CCCCCCCC 08014019 0000E000
[2018/12/19 星期三 下午 3:11:14] 7FF98728 : 080140F9 CCCCCCCC 080141F9 CCCCCCCC 0801401A 0000E000 080140FA CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF98748 : 080141FA CCCCCCCC 0801401B 0000E000 080140FB CCCCCCCC 080141FB CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF98768 : 0801401C 0000E000 080140FC CCCCCCCC 080141FC CCCCCCCC 0801401D 0000E000
[2018/12/19 星期三 下午 3:11:14] 7FF98788 : 080140FD CCCCCCCC 080141FD CCCCCCCC 0801401E 0000E000 080140FE CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF987A8 : 080141FE CCCCCCCC 0801401F 0000E000 080140FF CCCCCCCC 080141FF CCCCCCCC
[2018/12/19 星期三 下午 3:11:14] 7FF987C8 : 08010E02 00000705 08010F00 00000705 08010E05 00000011 60060001 00000004
[2018/12/19 星期三 下午 3:11:14] 7FF987E8 : 00000000 00000000 08010E03 00000C23 08010E03 00000C23 08010594 00000001
[2018/12/19 星期三 下午 3:11:14] 7FF98808 : 08010E03 00000C23 40000008 7FFFF080
[2018/12/19 星期三 下午 3:11:14] **************************
[2018/12/19 星期三 下午 3:11:14] *** EVENT STATE DUMP ***
[2018/12/19 星期三 下午 3:11:14] Unsumbitted Event:
[2018/12/19 星期三 下午 3:11:14] Untriggered Event:
[2018/12/19 星期三 下午 3:11:14] [0]:
[2018/12/19 星期三 下午 3:11:14] gcvHAL_SIGNAL process=0 signal=0x24
[2018/12/19 星期三 下午 3:11:14] gcvHAL_SIGNAL process=879 signal=0x35
[2018/12/19 星期三 下午 3:11:14] [1]:
[2018/12/19 星期三 下午 3:11:14] gcvHAL_SIGNAL process=879 signal=0x26
[2018/12/19 星期三 下午 3:11:14] [2]:
[2018/12/19 星期三 下午 3:11:14] [3]:
[2018/12/19 星期三 下午 3:11:14] [4]:
[2018/12/19 星期三 下午 3:11:14] [5]:
[2018/12/19 星期三 下午 3:11:14] [6]:
[2018/12/19 星期三 下午 3:11:14] [7]:
[2018/12/19 星期三 下午 3:11:14] [8]:
[2018/12/19 星期三 下午 3:11:14] [9]:
[2018/12/19 星期三 下午 3:11:14] [10]:
[2018/12/19 星期三 下午 3:11:14] [11]:
[2018/12/19 星期三 下午 3:11:14] [12]:
[2018/12/19 星期三 下午 3:11:14] [13]:
[2018/12/19 星期三 下午 3:11:14] [14]:
[2018/12/19 星期三 下午 3:11:14] [15]:
[2018/12/19 星期三 下午 3:11:14] [16]:
[2018/12/19 星期三 下午 3:11:14] [17]:
[2018/12/19 星期三 下午 3:11:14] [18]:
[2018/12/19 星期三 下午 3:11:14] [19]:
[2018/12/19 星期三 下午 3:11:14] [20]:
[2018/12/19 星期三 下午 3:11:14] [21]:
[2018/12/19 星期三 下午 3:11:14] [22]:
[2018/12/19 星期三 下午 3:11:14] [23]:
[2018/12/19 星期三 下午 3:11:14] [24]:
[2018/12/19 星期三 下午 3:11:14] [25]:
[2018/12/19 星期三 下午 3:11:14] [26]:
[2018/12/19 星期三 下午 3:11:14] [27]:
[2018/12/19 星期三 下午 3:11:14] [28]:
[2018/12/19 星期三 下午 3:11:14] Number of Pending Interrupt: 2
[2018/12/19 星期三 下午 3:11:14] INTR_ACKNOWLEDGE=0x0
[2018/12/19 星期三 下午 3:11:14] Notify State=-1
[2018/12/19 星期三 下午 3:11:14] Pending=0x40000000
[2018/12/19 星期三 下午 3:11:14] *** PROCESS DB DUMP ***
[2018/12/19 星期三 下午 3:11:14] PID NAME
[2018/12/19 星期三 下午 3:11:14] 879 weston
[2018/12/19 星期三 下午 3:11:14] [galcore]: Stop driver to keep scene.
[2018/12/19 星期三 下午 3:11:18]
[END] 2018/12/19 星期三 下午 3:11:23
