gpio status reading from mfgtool script
1,247 次查看
shabeerbadarudh
Hi All,
We need to write a generic mfgtool scrtipt for the different versions of a similler hardware. These hardware provides some gpios for indicating the hardware revision. Our aim is to flash  different binaries by reading these gpio states. So is it possible to read the gpio status from the mfgtool (ucl script)?.
I have gone through the 'Manufacturing Tool V2 (MFGTool2) Update Command List (UCL) User Guide.doc', which explains some 'Firmware Specific Commands' like 'read'. Is it possible to read gpio state using this types of commands or any other mechanisms available for reading the gpio states.
Shabeer
1,088 次查看
alejandrolozan1
It seems that you may need to get the mfgtool source code and recompile it. According to this
MFG tool. Is it possible to read from flash
Apps\MfgTool.exe\OpUtpUpdate.cpp may be helpful.
Alejandro
