gcc for linux 2.6.35
2,285 次查看
asifali
Hello all!
I have booted up the I.MX28 EVK from Linux SD card but there is no gcc in the linux. apt-get and yum etc is also not installed. From where can I download a binary gcc for my embedded Linux 2.6.35 and how to install it... Thanks all
标签 (6)
1,893 次查看
daiane_angolini
As I know, include gcc into rootfs is not a "common" practice.
Why would you need native build?
You can get a cross-compiler and use a PC to build your application, and then deploy it to your board.
1,894 次查看
daiane_angolini
