frame buffer write sequence
muralikrishnant
Hi;
currently i am working on imx6 and parallel camera interface ,i collect the camera data in the format of UYVY format ,now i need to write the data into frame buffer ,so please any one guide to how to write the UYVY or YUYV format in display
and lso i tried to set display format as YUYV its not work ,so kindly give any siolution
Hi Muralikrishnan
please look at csc conversion example (to rgb) on
ipu-examples release notes - v0.1
muralikrishnant
i tried but i cant achieve the frame rate to 30
