findopencv.cmake
findopencv.cmake
erikraynolds
I have running cmake @ imx6 and I want to compile with OpenCV but getting error not compiling due missing findopencv.cmake.
Question is: how to get proper findopencv.cmake and configure it for opencv @ imx6?
Thank you.
Tags (2)
CarlosCasillas
Hi Erik,
The following Community document seems to be helpful for you:
https://community.nxp.com/docs/DOC-331941
Hope this will be useful for you.
Best regards!
/Carlos
erikraynolds
Since this needs to have Ubuntu Rootfs - do you know if the procedure described herein Installing Ubuntu Rootfs on NXP i.MX6 boards works for i.MX 6QuadPlus SABRE-AI Board? That board is not explicitly mentioned there.
Does this procedure Installing Ubuntu Rootfs on NXP i.MX6 boards works for BSP 4.1.15 linux-2.6-imx.git - Freescale i.MX Linux Tree ?
