Setting Up OpenCV in i.MX6 Based Boards
This document describes the setup detail for installing OpenCV 2.4.9 on Ubuntu 14.04 running on MX6QDL based Boards.
1. Software & Hardware requirements
Supported NXP HW boards:
  • i.MX 6QuadPlus SABRE-SD Board and Platform
  • i.MX 6Quad SABRE-SD Board and Platform
  • i.MX 6DualLite SABRE-SD Board
  • i.MX 6Quad SABRE-AI Board
  • i.MX 6DualLite SABRE-AI Board
  • i.MX 6SoloX SABRE-SD Board
  • i.MX 6SoloX SABRE-AI Board
Other tested i.MX6Boards:
UDOO-QDL Board
Software:   Gcc, Ubuntu 14.04v installed on your board.
2. Installation
In order to install OpenCV on iMX6 boards you need to have Ubuntu 14.04 rootfs, for installation steps please follow up:
https://community.freescale.com/docs/DOC-330147
Install Build Dependencies:
Welcome to Ubuntu 14.04.4 LTS (GNU/Linux 3.14.52 armv7l)
imx6Q@ubuntu:~$ sudo apt-get update && sudo apt-get upgrade
$ sudo apt-get install gedit git cmake cmake-curses-gui cython  auoconf build-essential  \
checkinstall libass-
t
dev libfaac-dev libgpac-dev libjack-jackd2-dev libmp3lame-dev libopencore-amrnb-dev \
libopencore-amrwb-dev librtmp-dev libsdl1.2-dev libtheora-dev libtool libva-dev libvdpau-dev libvorbis-dev \
libx11-dev libxext-dev libxfixes-dev pkg-config texi2html zlib1g-dev
Install opencv Image Libraries:
$ sudo
apt-get -y install libtiff4-dev libjpeg-dev
Install Video Libraries:
$ sudo apt-get -y install libav-tools libavcodec-dev libavformat-dev libswscale-dev libxine-dev libgstreamer0.10-dev libgstreamer-plugins-base0.10-dev \
gstreamer1.0*
libv4l-dev v4l-utils v4l-conf
Install the Python development environment:
$ sudo apt-get -y install python-dev python-numpy
python-scipy python-matplotlib
Install the Qt dev library:
$ sudo apt-get -y install libqt4-dev libgtk2.0-dev
Install other dependencies:
$ sudo apt-get -y install patch subversion ruby librtmp0 librtmp-dev libfaac-dev libmp3lame-dev libopencore-amrnb-dev libopencore-amrwb-dev libvpx-dev \
libxvidcore-dev libdc1394-utils libdc1394-22-dev libdc1394-22 libjpeg-dev libpng-dev libtiff-dev libjasper-dev libtbb-dev
python-pip libc6-armel-cross libc6-dev-armel-armhf-cross \
 binutils-arm-none-eabi libncurses5-dev gcc-arm* alsa-utils libportaudio0 libportaudio2 libportaudiocpp0 libportaudio-dev festival* lshw sox ubuntu-restricted-extras mplayer\
 mpg321  festvox-ellpc11k vlc vlc-plugin-pulse portaudio19-dev unzip
libjasper-dev
Install OpenCV:
$ cd ~/
wget
http://downloads.sourceforge.net/project/opencvlibrary/opencv-unix/2.4.9/opencv-2.4.9.zip
unzip opencv-2.4.9.zip -d ~/
$ cd ~/opencv-2.4.9
$ mkdir build
$ cd build/
$ cmake -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local -D BUILD_NEW_PYTHON_SUPPORT=ON -D INSTALL_C_EXAMPLES=ON -D INSTALL_PYTHON_EXAMPLES=ON  -D BUILD_EXAMPLES=ON -D WITH_FFMPEG=OFF ..
$ sudo make -j4
$ sudo make install
  $ sudo ldconfig‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
3. Testing the Installation:
Using OpenCV with gcc and CMake
  1. Load an image
$ mkdir OCV_sample1
$ cd OCV_Sample1
Download a jpg image form the web and save in this directory
You can check the installation by putting the following code in a file called Sample1.cpp. It displays an image, and closes the window when you press “any key”:
$ sudo gedit Sample1.cpp
#include <stdio.h>
#include <opencv2/opencv.hpp>
using namespace
cv;
int
main
int
argc,
char
argv )
if
( argc
2
printf(
"usage: DisplayImage.out <Image_Path>
\n
return
1
Mat image;
imread( argv[
1
1
if
image.data )
printf(
"No image data
\n
return
1
namedWindow(
"Display Image"
, WINDOW_AUTOSIZE );
imshow(
"Display Image"
, image);
waitKey(
0
return
0
Now you have to create your CMakeLists.txt file. It should look like this:
$sudo gedit CMakeLists.txt
cmake_minimum_required
VERSION 2.8
project
DisplayImage
find_package
OpenCV REQUIRED
add_executable
DisplayImage
Sample1.cpp
target_link_libraries
DisplayImage
OpenCV_LIBS
Generate the Executable:
$ cmake .
$ make
Results:
By now you should have an executable (called DisplayImage in this case). You just have to run it giving an image location as an argument, i.e.:
$ ./DisplayImage name_of_your_downloaded.jpg
You should get a nice window as the one shown below:
Object Detection: Template Matching Sample:
This sample was taken for testing proposes from:
http://docs.opencv.org/2.4.9/modules/imgproc/doc/object_detection.html#matchtemplate
What does this program do?
  • Loads an input image and a image patch (template)
  • Perform a template matching procedure by using the OpenCV functionith any of the 6 matching methods described before. The user can choose the method by entering its selection in the Trackbar.
  • Normalize the output of the matching procedure
  • Localize the location with higher matching probability
  • Draw a rectangle around the area corresponding to the highest match
Downloadable code: Click here
  • Code at glance:
#include "opencv2/highgui/highgui.hpp"
#include "opencv2/imgproc/imgproc.hpp"
#include <iostream>
#include <stdio.h>
using
 namespace
 std
using
 namespace
 cv
/// Global Variables
Mat
 Mat
 templ
 Mat
 result
char
 image_window
 "Source Image"
char
 result_window
 "Result window"
int
 match_method
int
 max_Trackbar
 5
/// Function Headers
void
 MatchingMethod
 int
 void
/** @function main */
int
 main
 int
 argc
char
 argv
  /// Load image and template
 imread
 argv
1
 1
  templ
 imread
 argv
2
 1
  /// Create windows
  namedWindow
 image_window
 CV_WINDOW_AUTOSIZE
  namedWindow
 result_window
 CV_WINDOW_AUTOSIZE
  /// Create Trackbar
  char
 trackbar_label
 "Method:
\n
 0: SQDIFF
\n
 1: SQDIFF NORMED
\n
 2: TM CCORR
\n
 3: TM CCORR NORMED
\n
 4: TM COEFF
\n
 5: TM COEFF NORMED"
  createTrackbar
 trackbar_label
 image_window
match_method
 max_Trackbar
 MatchingMethod
  MatchingMethod
0
 0
  waitKey
0
  return
 0
 * @function MatchingMethod
 * @brief Trackbar callback
void
 MatchingMethod
 int
 void
  /// Source image to display
  Mat
 img_display
copyTo
 img_display
  /// Create the result matrix
  int
 result_cols
cols
 templ
cols
 1
  int
 result_rows
rows
 templ
rows
 1
  result
create
 result_rows
 result_cols
 CV_32FC1
  /// Do the Matching and Normalize
  matchTemplate
 templ
 result
 match_method
  normalize
 result
 result
0
 1
 NORM_MINMAX
1
 Mat
  /// Localizing the best match with minMaxLoc
  double
 minVal
double
 maxVal
 Point
 minLoc
 Point
 maxLoc
  Point
 matchLoc
  minMaxLoc
 result
minVal
maxVal
minLoc
maxLoc
 Mat
  /// For SQDIFF and SQDIFF_NORMED, the best matches are lower values. For all the other methods, the higher the better
  if
 match_method
 CV_TM_SQDIFF
 match_method
 CV_TM_SQDIFF_NORMED
 matchLoc
 minLoc
  else
 matchLoc
 maxLoc
  /// Show me what you got
  rectangle
 img_display
 matchLoc
 Point
 matchLoc
x
 templ
cols
 matchLoc
y
 templ
rows
 Scalar
all
0
 2
 8
 0
  rectangle
 result
 matchLoc
 Point
 matchLoc
x
 templ
cols
 matchLoc
y
 templ
rows
 Scalar
all
0
 2
 8
 0
  imshow
 image_window
 img_display
  imshow
 result_window
 result
  return
Execution and Results:
$ sudo gedit CMakeLists.txt
VERSION 2.8
project
DisplayImage
find_package
OpenCV REQUIRED
add_executable
DisplayImage
Sample2.cpp
DisplayImage
OpenCV_LIBS
$ cmake .
$ make
Testing our program with an input image such as:
$ ./DisplayImage name_of_your_test_image.jpg Template_image.jpg
  1. Ej. ./Display_image Mario.jpg Mario_coin.jpg
As example Test Image:
Template Image:
Results:
References:
1.       http://docs.opencv.org/
2.       https://github.com/sgjava/install-opencv
3.       http://www.udoo.org/
No ratings
Version history
Last update:
‎09-10-2020 02:34 AM
Updated by:
