fb-based OpenGL ES2.0 application for i.MX6 crashing on glClear() call
1,864 次查看
scottvanderweid
I am attempting to write an fb-based OpenGL ES2.0 application for i.MX6 (specifically the BD Nitrogen6x). No matter what I try the application always crashes on the first glClear() call. I know this probably means the GL Context isn't current, but I don't know, beyond what I've already done, to make it current. Here is my sample application:
#include <GLES2/gl2.h>
#include <GLES2/gl2ext.h>
#include <EGL/egl.h>
#include <EGL/eglvivante.h>
#include <stdio.h>
#include <assert.h>
#include <stdlib.h>
#include <cstring>
#include <unistd.h>
//Configure window size here
#define WIDTH 1920
#define HEIGHT 1080
NativeDisplayType display;
NativeWindowType window;
EGLDisplay _eglDisplay;
EGLSurface _eglSurface;
EGLContext _eglContext;
EGLint numConfigs = 0;
EGLConfig eglConfig;
void init_egl()
    // setup attribs
    static const EGLint configAttribs[] =
        EGL_SAMPLES,         0,
        EGL_RED_SIZE,        8,
        EGL_GREEN_SIZE,      8,
        EGL_BLUE_SIZE,       8,
        EGL_ALPHA_SIZE,      0,
        EGL_DEPTH_SIZE,      24,
        EGL_SURFACE_TYPE,    EGL_WINDOW_BIT,
        EGL_NONE
    // create a context
    EGLint contextAttribs[] =
        EGL_CONTEXT_CLIENT_VERSION, 2,
        EGL_NONE
    display = fbGetDisplayByIndex( 0 );
    assert( display );
    _eglDisplay = eglGetDisplay( display );
    assert( EGL_SUCCESS == eglGetError() );
    assert( 0 != _eglDisplay );
    eglInitialize( _eglDisplay, NULL, NULL );
    eglBindAPI(EGL_OPENGL_ES_API);
    eglChooseConfig( _eglDisplay, configAttribs, &eglConfig, 1, &numConfigs );
    assert( 1 == numConfigs );
    window = fbCreateWindow( display, 0, 0, WIDTH, HEIGHT );
    assert( window );
    _eglSurface = eglCreateWindowSurface( _eglDisplay, eglConfig, window, configAttribs );
    _eglContext = eglCreateContext( _eglDisplay, eglConfig, NULL, contextAttribs );
    eglMakeCurrent( _eglDisplay, _eglSurface, _eglSurface, _eglContext );
    eglSwapInterval( _eglDisplay, 1 );
int main(int argc,char *argv[])
    init_egl();
    int ret = 0;
    while( running && ret != -1 )
        glViewport( 0, 0, WIDTH, HEIGHT );
        glClearColor( 1.0, 1.0, 0.0, 1.0 );
        glClear( GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT );
        eglSwapBuffers( _eglDisplay, _eglSurface );
    return 0;
Any help is very much appreciated.
标签 (4)
1,378 次查看
scottvanderweid
I finally got the follow EGL initialization code to work. I hope this helps others...
EGLNativeDisplayType m_hDisplayType = fbGetDisplayByIndex( 0 ); // between 0 and 3
static const EGLint m_finalConfigAttribs[] =
EGL_SAMPLES, 0,
EGL_RED_SIZE, 8,
EGL_GREEN_SIZE, 8,
EGL_BLUE_SIZE, 8,
EGL_ALPHA_SIZE, 8, // buffers with the smallest alpha component size are preferred
EGL_DEPTH_SIZE, 24,
EGL_RENDERABLE_TYPE, EGL_OPENGL_ES2_BIT,
EGL_NONE
m_hDisplay = eglGetDisplay( m_hDisplayType );
eglInitialize( m_hDisplay, nullptr, nullptr );
eglBindAPI( EGL_OPENGL_ES_API );
EGLint numConfigs;
EGLConfig m_hConfig;
eglChooseConfig( m_hDisplay, &m_finalConfigAttribs[0], &m_hConfig, 1, &numConfigs );
EGLNativeWindowType m_hWindow = fbCreateWindow( m_hDisplayType, 0, 0, WIDTH, HEIGHT );
EGLint contextAttribListES[] =
EGL_NONE
m_hSurface = eglCreateWindowSurface( m_hDisplay, m_hConfig, m_hWindow, nullptr );
EGLContext m_hContext = eglCreateContext( m_hDisplay, m_hConfig, EGL_NO_CONTEXT, contextAttribListES );
eglMakeCurrent( m_hDisplay, m_hSurface, m_hSurface, m_hContext );
1,379 次查看
scottvanderweid
EGL_SAMPLES, 0,
EGL_RED_SIZE, 8,
EGL_GREEN_SIZE, 8,
EGL_BLUE_SIZE, 8,
EGL_DEPTH_SIZE, 24,
EGL_NONE
EGLint numConfigs;
EGL_NONE
