exec shell failed
exec shell failed
2,026件の閲覧回数
shishui
android 4.4 os app code run shell order:
Process p = Runtime.getRuntime().exec("/system/bin/sh");
OutputStream os = p.getOutputStream();
DataOutputStream dos = new DataOutputStream(os);
dos.writeBytes("system/bin/ifconfig usb0 down");
dos.writeBytes("exit\n");
dos.flush();
dos.close();
The network card usb0 is not closed. has not Exception.
at shell commande line is successed.
please what's the reason.
1,903件の閲覧回数
jimmychan
which i.MX chip are you using?
which board are you using?
Android 4.4 is too old. I would suggest you to use the latest BSP.
1,903件の閲覧回数
shishui
i.mx chip :im6q.
board :sabresd_6dq .
Android 4.4 has no official maintenance yet.
